Hallo,
I noticed a misbehavior when using _mm_set_epi16 with /arch:AVX(2). In debug mode I observe the following results of the following call:
mmTemp11 = _mm_set_epi16( 0, src11, 0, src10, 0, src11, 0, src10 );
-> mmTemp11.m128i_i16 0x00000074cf53bc80 {-2, -1, -2, 0, -2, 0, -2, 0}short[8] (for those unfamiliar with MSVC debugger, the problem is the bits 16:31 being set, when they clearly should be 0).
When src11=src10=-2. For positive values all works fine.
In release and profile configs I observe the program results being incorrect.
The problem does not occur with /arch:SSE42 or lower.
For now, I found the following workaround, but of course it would be nice if the program worked as intended:
mmTemp11 = _mm_cvtepu16_epi32( _mm_set_epi16( 0, 0, 0, 0, src11, src10, src11, src10 ) );
I don't think this behavior is intended. It works ok with gcc7/clang/msvc-19.16.
Compiler version is the one bundled with Intel Parallel Studio XE 2019.03.
Adam
- Tags:
- CC++
- Development Tools
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
Found a minimal example to present the compiler bug. This only produces incorrect results when compiling with /Ob1, e.g.
icl /Ob1 /arch:CORE-AVX2 icc_bug.c
The following code demonstrates the problem:
#include <stdio.h> #include <emmintrin.h> void init_arr(short *arr) { arr[0] = -2; arr[1] = -2; } int main() { short arr[4]; init_arr( arr ); __m128i v = _mm_set_epi16( 0, arr[1], 0, arr[0], 0, arr[1], 0, arr[0] ); int b0_31 = _mm_cvtsi128_si32( v ); printf( "0x%x\n", ( b0_31 >> 16 ) & 0xffff ); }
I just wanted to clarify: the correct result should be zero and incorrect one should be 0xffff?
Yes, exactly. The expected results is 0x0, but with the specified compiler options the output 0xffff is being produced.
I've reported this case to the Developer. Case number is CMPLRIL0-31587
Is there anywhere I can follow the ticket?
This is for internal tracking only.
