When I attempt to ./configure for a program install, the configure scripts will hang. Running a top will show dozens of mpiicc processes running concurrently while configure is hanging. I can not reproduce the issue with icc, it only does this with mpiicc.
For example...
setenv install_prefix '/stor400a/jbzambon/netcdf_intel2018/' source /usr/local/apps/intel2018/build/parallel_studio_xe_2018.3.051/psxevars.csh source /usr/local/apps/intel2018/build/compilers_and_libraries_2018.3.222/linux/mpi/bin64/mpivars.csh setenv CC mpiicc setenv CXX mpiicc setenv FC mpiifort setenv F9X mpiifort setenv I_MPI_CC mpiicc setenv I_MPI_CXX mpiicpc setenv I_MPI_F77 mpiifort setenv I_MPI_F90 mpiifort setenv DM_FC mpiifort setenv DM_CC mpiicc setenv CFLAGS '-O3 -xHost -ip -static-intel -heap-arrays -static_mpi -L'$install_prefix'/build/lib/ -I'$install_prefix'/build/include/' setenv CXXFLAGS '-O3 -xHost -ip -static-intel -heap-arrays -static_mpi -L'$install_prefix'/build/lib/ -I'$install_prefix'/build/include/' setenv FCFLAGS '-O3 -xHost -ip -static-intel -heap-arrays -static_mpi -L'$install_prefix'/build/lib/ -I'$install_prefix'/build/include/' setenv I_MPI_CFLAGS '-O3 -xHost -ip -static-intel -heap-arrays -static_mpi -L'$install_prefix'/build/lib/ -I'$install_prefix'/build/include/' setenv I_MPI_LDFLAGS '-O3 -xHost -ip -static-intel -heap-arrays -static_mpi -L'$install_prefix'/build/lib/ -I'$install_prefix'/build/include/' cd $install_prefix rm -rf szip-2.1.1.tar.gz rm -rf szip-2.1.1 wget https://support.hdfgroup.org/ftp/lib-external/szip/2.1.1/src/szip-2.1.1.tar.gz tar -zxvf szip-2.1.1.tar.gz cd szip-2.1.1 ./configure --prefix $install_prefix/build make make check make install
Will hang on the configure script at "checking build system type...". However....
setenv CC icc setenv CXX icc setenv FC ifort setenv F9X ifort
Will work. Here's a screenshot of the two terminals side by side. The left terminal is running the configure script. The right terminal shows the dozens of mpiicc processes running. I can reproduce the issue by simply setting
and checking the version
mpiicc -v
which results in an infinite loop of mpiicc processes. Versions...
jbzambon@node01 szip-2.1.1 > mpiicc -v mpiicc for the Intel(R) MPI Library 2018 Update 3 for Linux* Copyright(C) 2003-2018, Intel Corporation. All rights reserved. icc: command line warning #10006: ignoring unknown option '-static_mpi' icc version 18.0.3 (gcc version 5.4.0 compatibility) jbzambon@node01 szip-2.1.1 > icc -v icc version 18.0.3 (gcc version 5.4.0 compatibility) jbzambon@node01 szip-2.1.1 > ifort -v ifort version 18.0.3 jbzambon@node01 szip-2.1.1 > mpiifort -v mpiifort for the Intel(R) MPI Library 2018 Update 3 for Linux* Copyright(C) 2003-2018, Intel Corporation. All rights reserved. ifort version 18.0.3
Any help is appreciated, thanks!
-Joe
- Tags:
- CC++
- Development Tools
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
Hi Joe, have you been able to find a solution to this? I am experiencing the same error...
