Hi, i recently have installed Intel system studio 19 update 3 to test it, and after doing some small projects and exploring I found one nasty bug that makes my test project on stall, I did try to go around the bug no luck.
The bug that is that some strings are not stored correctly, I don't know how rare is this bug.
//static CHAR szBasedNamesObject[] = "\\??\\BasedNamedObject\\"; //static VOLATILE CHAR szBasedNamesObject[] = "\\??\\BasedNamedObject\\"; static CONST CHAR szBasedNamesObject[] = "\\??\\BasedNamedObject\\"; BOOL CheckInstance(VOID) { DLOG1(DLG_FLT_INFO, "Checking instance"); DLOG1(DLG_FLT_HIGHLIGHT, "You workin fam ? %s", szBasedNamesObject); printf("%s\n", szBasedNamesObject); DLOG1(DLG_FLT_INFO, "Done"); return TRUE; }
The string is stored as (PΣá6¿Ö!║æedObject\ instead of \??\BasedNamedObject\ the only way it would be stored correctly is if i make it const. If you are wondering if the function DLOG1 is the problem i checked with printf and with windbg to see if the problem is on mine side.
Here is the assembly:
003110a2 6854403100 push offset slave!szBasedNamesObject (00314054) 003110a7 6850333100 push offset slave!NtapiSyscallsX86+0x118 (00313350) 003110ac 6864333100 push offset slave!NtapiSyscallsX86+0x12c (00313364) 003110b1 6806003f1e push 1E3F0006h 003110b6 e8950a0000 call slave!$DLogSendExLocal (00311b50)
and some windbg:
0:000:x86> da slave!szBasedNamesObject 00314054 "(P..6....!..edObject\."
I did try /Qstd=c99 and /Qstr=c11, also removing and adding /GF too see if this is the problem. Changing the string doesn't fix the problem or making it array of bytes too. I hope all the information needed is here. Overall great compiler and sorry for my bad english.
- Tags:
- CC++
- Development Tools
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
correction: If you are wondering if the function DLOG1 is the problem I checked the string using printf and is the same result.
Again sorry for my bad english
Does your test project work with Microsoft compiler? Can you provide us a stand alone test case to investigate?
Sorry for not being active, the problem is with /Qipo and xilink, if I compile a file with /Qipo and use xilink seems to creates the problem, and there is no problem with microsoft compiler
