Hi all,
I might be asking something stupid, but I have a problem with running a model which I finally manage to compile in a mac. I already worked with the model in a PC, and I'm using the same makefile for the compilation (adapted, as far as I'm able to, to the Mac paths). However, I can't run it because it's still looking for the libraries in the /home/myuser folder instead of the Mac's equivalent /Users/myuser, where the library is actually placed.
This is the error I get when trying to run it:
dyn1003-29:archivos_para_correr_programa_vs6 mmartinc$ ./motif_lpj-step1a
dyld: Library not loaded: /home/mmartinc/local/lib/libnetcdf_c++.4.dylib
Referenced from: /Users/mmartinc/Desktop/archivos_para_correr_programa_vs6/./motif_lpj-step1a
Reason: image not found
Trace/BPT trap
This is the part of the makefile where the paths are set up:
NETCDF =/Users/mmartinc/local
FC = ifort
FCOPTIONS = -fpp -O3
CPPOPTIONS = -I$(NETCDF)/include
CXX = icpc
CXXOPTIONS = -O3
CXXOPTIONS = -std=c++0x -O3
LD = $(FC)
LDLIBS1 = -I$(NETCDF)/lib/lnetcdf_c++
LDLIBS2 = -I$(NETCDF)/lib/-lnetcdf -lstdc++ -L$(NETCDF)/lib -lnetcdf -lnetcdf_c++
LDLIBS = -L$(NETCDF)/lib -lnetcdf_c++ -lnetcdf -L/Developer/opt/intel -lstdc++
Do you have any idea of where is it getting the /home/myuser path from??
Thanks in advance!!
Trace/BPT trap
FC = ifort
CXX = icpc
CXXOPTIONS = -O3
LD = $(FC)
Thanks in advance!!
Starting with basics, you must have the environment variable NETCDF set so that it agrees with the way your file system is set up. Typically, you must first install netcdf there (possibly building it from source).
Thanks for the answer, TimP
I'm not sure if I'm following you. I already installed the NetCDF from source, and /Users/mmartinc/local is where it's placed, so I don't see how can it be related to the error...:-S
The answer is there for the asking:
It is likely that the library motif_lpj-step1a... was built with a reference to /home/mmartinc/local/lib/libnetcdf_c++.4.dylib. When the former is read by the linker it looks for the reference, and does not find it.
Did you build these libraries or do they come from elsewhere with precribed locations?
Hi mecej4,
That's what I thought at the beginning, but motif_lpj-step1a is created during the compilation (is one of the executables I get). I've searched for any path pointing to the /home directory amongst the files involved in the compilation, but I found nothing.
The makefile compiles together two sections of the model, one in fortran (the main part) and the other one in c++ (for input-outputs). The run is controled by a configuration file, on which the paths have also been changed.
I tried to change dyld path but still doesn't work, and with my knowledge I'm running out of ideas..:-S
Thanks in advance!!
Thanks in advance!!
I am not familiar with OSX; is there a utility similar to "ldd" in Linux, which when run on an executable or shared library lists the library dependencies? If so, you could run it on your motif_lpj-step1a object.
Thanks, I'll look out for it and tell you if I make any advances.
Ok,
I found the command for Mac, which is otool (otool -l filename for the loading information). The info about where does it look for the libraries is at the end of the file, and I copy it here:
Load command 10
cmd LC_LOAD_DYLIB
cmdsize 72
name /home/mmartinc/local/lib/libnetcdf_c++.4.dylib (offset 24)
time stamp 2 Thu Jan 1 01:00:02 1970
current version 6.0.0
compatibility version 6.0.0
Load command 11
cmd LC_LOAD_DYLIB
cmdsize 72
name /home/mmartinc/local/lib/libnetcdf.7.dylib (offset 24)
current version 9.1.0
compatibility version 9.0.0
Load command 12
cmd LC_LOAD_DYLIB
cmdsize 56
name /usr/lib/libstdc++.6.dylib (offset 24)
current version 7.9.0
compatibility version 7.0.0
Load command 13
cmd LC_LOAD_DYLIB
cmdsize 56
name /usr/lib/libgcc_s.1.dylib (offset 24)
current version 830.0.0
compatibility version 1.0.0
Load command 14
cmd LC_LOAD_DYLIB
cmdsize 48
name /usr/lib/libmx.A.dylib (offset 24)
current version 315.0.0
Load command 15
cmd LC_LOAD_DYLIB
cmdsize 56
name /usr/lib/libSystem.B.dylib (offset 24)
current version 125.2.11
But I still don't know how can I change those paths..:-S
Load command 10
cmd LC_LOAD_DYLIB
cmdsize 72
Load command 11
cmd LC_LOAD_DYLIB
cmdsize 72
Load command 12
cmd LC_LOAD_DYLIB
cmdsize 56
Load command 13
cmd LC_LOAD_DYLIB
cmdsize 56
Load command 14
cmd LC_LOAD_DYLIB
cmdsize 48
Load command 15
cmd LC_LOAD_DYLIB
cmdsize 56
I tried to open the executable motif_lpj-step1a and change the paths directly from the file (which is not the best, for sure, as I still don't know where those paths are created), and it didn't work either:
-bash: ./motif_lpj-step1a: Malformed Mach-o file
What am I missing?
Thanks!
What am I missing?
Thanks!
I finally could run it!!
I had already tried: DYLD_LIBRARY_PATH=/Users/mmartinc/local/lib:$DYLD_LIBRARY_PATH, but it did't work. Now I tried: export DYLD_LIBRARY_PATH=/Users/mmartinc/local/lib and worked perfectly.
I don't really understand what's the difference between both, but my model is finally running!
Cheers
Cheers
the 'export' controls whether child processes inherit the env variable. In most cases, you DO want new child processes launched/spawned from the current process to inherit your environment. Without the export, when you start the program using this lib, that process would not inherit the DYLD_LIBRARY_PATH.
I just about always use 'export' when setting env vars - can't remember last time I didn't.
As for setting the path to your /Users/mmartinc/local/lib - the configure --prefix option sets this.
You might consider putting the libs in /usr/local (configure --prefix=/usr/local ). However, home is kind of convenient on a Mac since when you migrate your data to a new Mac it will surely copy over the libs from your home dir. Downside is that it's an unusual place to store general purpose libraries.
ron
ron
Thanks a lot, Ron
I am implementing a stack in c++ using classes it works if i write whole code in 1 cpp file but when i made a seprate header file i got errors of type :
error LNK2019: unresolved external symbol "public: void __thiscall Stack<int>::Push(int)" (?Push@?$Stack@H@@QAEXH@Z) referenced in function _main
tell me how can i resolve this
