After spending one day debugging some code I've found some really strange behaviour: Consider the following code
[cpp]
#include<iostream>
#include<type_traits>
struct A {
A(A&& other) noexcept {}
~A() noexcept {}
struct B {
B(B&& other) noexcept {
~B() {}
int main() {
std::cout << std::is_nothrow_move_constructible<A>::value << std::endl;
std::cout << std::is_nothrow_move_constructible<B>::value << std::endl;
[/cpp]
If I compile this with Intel Composer XE2014 SP1 Update 1 on Windows I get the following output on the the console:
[cpp]
1
0
[/cpp]
This means essentially that std::is_no_throw_move_constructible returns true only if the Move constructor AND the Destructor are marked as noexcept. I think this is not what is written in the standard. (gcc 4.8.2 and Clang 3.4 give the correct outpout, i.e. 1,1)
Cheers,
Raffael
P.S.: You can find the source code also attached to this message.
This is the for the same reason as your other note, we do not support implicit noexcept on the Windows platform.
http://software.intel.com/en-us/forums/topic/500462
From our code:
/* Microsoft compilers do not yet (as of Visual C++ 2013) implement
noexcept. We therefore keep the traditional relaxed semantics for
destructors and operator delete. */
implicit_noexcept_enabled = FALSE;
Judy
Hi Judy,
Okay thanks for the answer. It's really too bad that it doesn't work completly but I have been able to work around it.
Cheers,
Raffael
