Intel® C++ Compiler
noob at setting up ICC
arquebus
I just installed ICC on Linux Mint, but the manual actually says I have to run:
source /opt/intel/bin/compilervars.sh ia32
everytime I want to use ICC on the command line. Im not very good at Linux, so could someone tell me how I set up ICC so its always on the path?
Alexander_W_Intel
The way I use to do that is to add the " source /opt/intel/bin/compilervars.sh ia32" line you already mentioned to the .bashrc file in your home directory. I'm not familiar with Mint linux, but it should work there as well.
Alex
arquebus
thanks Alex
I just discovered that ICC integrates into the CodeBlocks IDE perfectly by just selecting it in a dropdown menu without having to put ICC in my main path, so I'll call that good enough as CodeBlocks is my favorite IDE.
