Intel® C++ Compiler
offload to Iris Pro Graphics P580
Randy_S_
Sorry if this is slightly off-topic but I didn't see a more applicable forum. I am trying to use Cilk offload for GPGPU applications and I can't find a driver that works with the E3-1585v5 / Iris Pro P580 in Windows 10. I have tried several drivers, both using the installer and manual install. It appears that the offload driver is not getting installed on the system: [snip] C:\>gfx_sys_check -v Checking CPU family:6 model:5e type:0 stepping:3 (signature:506e3) Checking OS Windows 8 x64 graphics timeout set to default (2 seconds) Checking display device: Provider: Intel Corporation Description: Intel(R) Iris(TM) Pro Graphics P580 Version: 21.20.16.4678 device: Provider: ASPEED Description: ASPEED Graphics Family(WDDM) Version: 9.0.10.102 Checking Intel HD Graphics Driver failed to load library igfx11cmrt64.dll (error#126) [end snip] Running "dir /s igfx11cmrt64.dll" from C:\ shows that the offload driver files are not in the C:\Windows\Sys* folders. If I navigate to the folder I extracted the driver into, gfx_sys_check does recognize the device: [snip2] Checking Intel HD Graphics Driver DX11 version will be used cm_version=600 RT Dll version: (6.0.0.1189) JIT Dll version: (6.0.0.1189) CAP_KERNEL_COUNT_PER_TASK=16 CAP_KERNEL_BINARY_SIZE=65536 CAP_SAMPLER_COUNT=64 CAP_SAMPLER_COUNT_PER_KERNEL=16 CAP_BUFFER_COUNT=256 CAP_SURFACE2D_COUNT=256 CAP_SURFACE3D_COUNT=64 CAP_SURFACE_COUNT_PER_KERNEL=255 CAP_ARG_COUNT_PER_KERNEL=255 CAP_ARG_SIZE_PER_KERNEL=2016 CAP_USER_DEFINED_THREAD_COUNT_PER_TASK=262144 CAP_HW_THREAD_COUNT=504 CAP_SURFACE2D_FORMAT_COUNT=26 CAP_SURFACE3D_FORMAT_COUNT=2 CAP_VME_STATE_G6_COUNT=8 CAP_GPU_PLATFORM=Skylake CAP_GT_PLATFORM=GT4 CAP_MIN_FREQUENCY=350 CAP_MAX_FREQUENCY=1150 CAP_GPU_CURRENT_FREQUENCY=0 JIT version: 3.3 executing visa3.0 CmRT reported execution time 25999 nanosec executing visa3.1 CmRT reported execution time 9249 nanosec executing visa3.2 CmRT reported execution time 9083 nanosec GPU architecture: skylake vISA support: visa3.2 [end snip2] Visa3.x CmRT seems to work but it isn't clear to me if that is offload or something else like DX11, OpenCL, etc. I tried running some of the samples and my code--I thought they may run if I copy the exe into that folder; however, the code ran but from the execution time it was obviously running on a single CPU core and not offloaded. The code and samples both offload just fine on my other machine (i7-4810MQ w/HDG4600), so the driver issue notwithstanding, I can't rule out a compiler issue. I am using MSVS 2015 update 3 and Intel 2017 update 2 on both machines. Thanks, Randy
SergeyKostrov
Valued Contributor II
>>...I tried running some of the samples and my code... Do you use OpenMP v4.x offload functionality, or something else? Please provide more details.
Konstantin_B_Intel
In Win10 some of the driver files are kept in a different place, which is not in the PATH. Will be fixed in the upcoming compiler release. As a workaround, add the directory contained in the following registry entry to the PATH:
64-bit system:  HKEY_LOCAL_MACHINE\SOFTWARE\Intel\MDF\DriverStorePath
32-bit system: HKEY_LOCAL_MACHINE\Software\WOW6432Node\Intel\MDF\DriverStorePath
Typical content is:
C:\WINDOWS\System32\DriverStore\FileRepository\igdlh64.inf_amd64_f10b0c0616a02072
