I'm trying the new oneAPI 2023 (2023.0.0.20221201) and get into some trouble.
Since the ICPC complains that it will be abandoned sooner than later (fair enough), I switched to ICPX.
And now in my autotools project when compiling I got the following errors:
bfd plugin: LLVM gold plugin has failed to create LTO module: Not an int attribute (Producer: 'Intel.oneAPI.DPCPP.Compiler_2023.0.0' Reader: 'LLVM 14.0.6')
It occurs when libtool is applying 'ar cr' or 'ranlib' to a bunch of object to create a static library.
Then at final linking there are plenty of missing symbols.
It is not happening with previous version of oneAPI (2022.1.0.20220316).
Any clue on where I have to start digging to solve this issue? My Google attempts pointed me to an ld/ld.lld issue but I could not find any way to get something working.
Since this is a duplicate thread of https://community.intel.com/t5/Intel-C-Compiler/oneAPI-2023-linking-problems/m-p/1441944#M40598
we will no longer monitor this thread. We will continue addressing this issue in the other thread.
Thanks and Regards,
Aishwarya
