I try compiling my code as follows, using icc v 15.0.1.
icc -std=gnu99 -openmp -c foo.c
but I get these errors
error: "k" can only appear on one data scope attribute clause in an OpenMP pragma (except firstprivate and lastprivate)
#pragma omp parallel for
error: "X1" can only appear on one data scope attribute clause in an OpenMP pragma (except firstprivate and lastprivate)
for ( size_t k = 0; k < Nseg; ++k ) {
for ( size_t X1 = 0; X1 < numDet; ++X1 ) {
for ( size_t n = 0; n < intN
InputOutputInfo *io = &intInOut
gsl_function integrand;
integrand.params = (void*)&( io->par );
int stat;
double res, abserr;
const double scale1 = GET_COORD_SCALE(io->par.coordSys, io->par.coord1);
const double scale2 = GET_COORD_SCALE(io->par.coordSys, io->par.coord2);
const double scale12 = scale1 * scale2;
/* compute <phi_i phi_j> */
integrand.function = &CW_am1_am2_Phi_i_Phi_j;
stat = gsl_integration_qag (&integrand, io->ti, io->tf, epsabs, epsrel, limit, GSL_II
NTEG_GAUSS61, io->wksp, &res, &abserr);
if ( stat != 0 ) {
XLALPrintWarning ( "\n%s: GSL-integration 'gsl_integration_qag()' of <Phi_i Phi_j>>
did not reach requested precision!\n", __func__ );
XLALPrintWarning ( "xlalErrno=%i, seg=%zu, av_ij_n=%g, abserr=%g\n", io->par.errnuu
m, n, res, abserr );
io->av_ij = GSL_NAN;
} else {
io->av_ij = scale12 * res;
io->av_ij_err_sq = SQUARE( scale12 * abserr);
/* compute <phi_i> */
integrand.function = &CW_Phi_i;
io->par.coord = io->par.coord2;
if ( stat != 0 ) {
XLALPrintWarning ( "\n%s: GSL-integration 'gsl_integration_qag()' of <Phi_j> did nn
XLALPrintWarning ( "xlalErrno=%i, seg=%zu, av_j_n=%g, abserr=%g\n", io->par.errnumm
, n, res, abserr );
io->av_j = GSL_NAN;
} else {
io->av_j = scale2 * res;
io->av_j_err_sq = SQUARE( scale2 * abserr);
} /* for n < intN */
} // for X1 < numDet
} // for k < Nseg
I'd appreciate assistance on how to keep the code accepting -std=gnu99 on the build line, yet make the
source modifications necessary. Adding private and shared clauses has just led to different compilation errors.
thanks.
hello,
First question is why do you need nested parallel for here?
--Vladimir
Consider using
#pragma omp parallel for for ( size_t k = 0; k < Nseg; ++k ) { for ( size_t X1 = 0; X1 < numDet; ++X1 ) { for ( size_t n = 0; n < intN[X1]; ++n ) {
or
#pragma omp parallel for collapse(2) for ( size_t k = 0; k < Nseg; ++k ) { for ( size_t X1 = 0; X1 < numDet; ++X1 ) { for ( size_t n = 0; n < intN[X1]; ++n ) {
Jim Dempsey
Thanks much...indeed the nested parallelism wasn't needed and of course the error messages go away when just having one pragma at the top level.
