Intel® C++ Compiler
7875 Discussions
openmp task depend in c++ 15 compiler
pghysels
I'm experimenting with openmp task parallelism and the depend clause. The following code
#include <iostream>
//void solve(int N, double* a, double* b) {            // this works
template<typename S> void solve(int N, S* a, S* b) {   // this does not
  int T = 4;
#pragma omp taskgroup
    for (int i=0; i<N; i+=T) {
#pragma omp task depend(inout:b)
        for (int k=0; k<T; k++)
          for (int l=0; l<k; l++)
            b[i+k] -= a[i+k+(i+l)*N]*b[i+l];
      for (int j=i+T; j<N; j+=T)
#pragma omp task depend(in:b) depend(inout:b)
            for (int l=0; l<T; l++)
              b[j+k] -= a[j+k+(i+k)*N]*b[i+l];
int main(int argc, char* argv[]) {
  int N = 64;
  double* a = new double[N*N];
  double* b = new double;
  for (int k=0; k<N; k++)
    for (int l=0; l<N; l++)
      a[k+l*N] = 1./((k-l)*(k-l)+1);
  for (int i=0; i<N; i++) b = i;
  solve(N, a, b);
  for (int i=0; i<N; i++) std::cout << b << std::endl;
fails with
testDepend.cpp(9): error: invalid entity for this variable list in omp clause
Is this not allowed? It works when I remove the template parameter, ie, just make it double and both versions work with g++ 4.9.1.
I'm using icpc (ICC) 15.0.0 20140530. It's a beta version. Sorry if this is already fixed in a later version of the compiler.
TimP
Black Belt
It appears to work OK with 64-bit 15.0.0.108 20140726.
