Intel® C++ Compiler
openmp
thouraya87
I installed the compiltor of intel
in fact it is compiling but not the execution
icc -openmp prog.c -o prog
./prog
Here are the error message:
error while loading shared libraries: libiomp5.so: can not open shared object file: No such file or directory
i do
icc -openmp -static-intel prog.c -o prog
./prog
I have
OMP: Warning #2: Cannot open message catalog "libiomp5.cat":
OMP: System error #2: No such file or directory
OMP: Hint: Check NLSPATH environment variable, its value is "(null)".
OMP: Hint: Check LANG environment variable, its value is "fr_FR.UTF-8".
OMP: Info #3: Default messages will be used.
Thank you
TimP
-static-intel doesn't affect libiomp5; it is still linked dynamic, unless you set the specific option with -openmp-link, so you must provide the library, and point to it in LD_LIBRARY_PATH (as sourceing the iccvars script does) or by ldconfig. This is a separate question from the one of whether it is possible to change the run-time error messages from English to French.
thouraya87
hello
I am beginner with ubunto
if you tell me please how to access LD_LIBRARY_PATH
Thank you
aazue
Hi, salut
LANG=C;
export LANG
KMP_BLOCKTIME=0;
export KMP_BLOCKTIME
LD_LIBRARY_PATH=/opt/intel/Compiler/11.1/059/lib/intel64
export LD_LIBRARY_PATH
cd /opt/intel/ext.................
./icpc -ansi -fast -static -O2 -axSSSE3 -lpthread -openmp -openmp-lib=compat -march=core2 -mtune=core2 ton_prog_source.cc -o (le nom du binaire rsultant)
Kind regards (Cordialement)
Om_S_Intel
I have installed the Intel C++ compiler using default option during install. I use the following to get Intel 64 version of C++ compiler environment:
$source /opt/intel/Compiler/11.1/064/bin/iccvars.sh intel64
The above script sets the environment variable LD_LIBRARY_PATH automatically for you.
$ echo $LD_LIBRARY_PATH
/opt/intel/Compiler/11.1/064/lib/intel64:/opt/intel/Compiler/11.1/064/ipp/em64t/sharedlib:/opt/intel/Compiler/11.1/064/mkl/lib/em64t
The required files are available as given below:
/opt/intel/Compiler/11.1/064/lib/intel64/libiomp5.a
/opt/intel/Compiler/11.1/064/lib/intel64/libiomp5.so
thouraya87
Hello
I do
:/opt/intel/Compiler/11.1/064/lib/ia32
$LD_LIBRARY_PATH = /opt/intel/Compiler/11.1/064/lib/ia32/libiomp5.so
I have this message
bash: :/opt/intel/Compiler/11.1/064/lib/ia32: Aucun fichier ou dossier de ce type
thanks
TimP
If you have installed only the intel64 compiler, the /ia32/ directories won't be present. In any case, should you compile with the intel64 compiler, it will ignore any 32-bit libraries on the search path.
The PATH should not include any individual libraries, only the directories including the libraries. In accordance with the advice given you multiple times, the source commands will take care of setting LD_LIBRARY_PATH. You migh want to check what is there by
but over-writing the setting will remove what was there.
thouraya87
Hello
I do
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/opt/intel/Compiler/11.1/064/lib/ia32/libiomp5.so
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/opt/intel/Compiler/11.1/064/lib/ia32/libiomp5.a
icc -openmp mmv2.c -o mmv2
./mmv2
I do the execution there is the desired result but the warnings persist
how to please because I am limilt by a period
thank you
TimP
For the dynamic link with 32-bit libiomp5, at run time you need
(path to the directory, not including individual libraries, so the entry you quote is superfluous)
For the static link, you could include the full path, including libiomp5.a, in your link step during the build, if you choose not to use the openmp-link option supported by the compiler. Static .a libraries on LD_LIBRARY_PATH will be ignored.
Apparently, you have the correct paths set in addition to the useless entries. The extra entries are not the reason for the warning.
A previous responder suggested LANG and NLSPATH settings to suppress the warnings about lack of support for French language run-time error messages, but of course that would cancel the ability of other applications to display French.
thouraya87
hello
I do all the commande but the same warning persists but it executed well
he does not know the library open mp
OMP: Warning # 2: Can not open message catalog "libiomp5.cat"
OMP: System error # 2: No such file or directory
OMP: Hint: Check environment variable NLSPATH, its value is "(null)".
OMP: Hint: Check LANG environment variable, its value is "en_US.UTF-8".
OMP: Info # 3: Default messages will be used.
How? Please specify me the exact command
thank you very much
Lev_N_Intel
Please let me know exact version of libiomp5.so. Set environment variable KMP_VERSION to 1, run your application, and copy its output, for example:
$ export KMP_VERSION=1
$ ./mmv2
thouraya87
Hello
I do
./mmv2
Intel OMP performance library (dynamic) ver. 5.0.20091005 (C) Copyright 1997-2009 by Intel Corporation
Intel OMP library built 2009-10-05 17:36:31 UTC using Intel C++ Compiler 10.1
Intel OMP port library
Intel OMP nested library
Intel OMP alternative compiler support
Intel OMP 3.0 support
Intel OMP sibling library
Intel OMP no tracefile support
Intel OMP no consistency checking support
Intel OMP INTEGER*8 dynamic dispatch support
Intel OMP INTEGER*8 dynamic scheduling support
Intel OMP Helper Thread support
Intel OMP not using thread affinity support
Intel OMP debugger support version 1.1
Intel OMP not using Intel RML support
thank you
aazue
Hi thouraya87
Just cut an paste at you shell
first if you have 64 version or second if you have 32
LANG=C;
export LANG
KMP_BLOCKTIME=0;
LD_LIBRARY_PATH=/opt/intel/Compiler/11.1/064/lib/intel64;
LANG=C;
export LANG
KMP_BLOCKTIME=0;
LD_LIBRARY_PATH=/opt/intel/Compiler/11.1/064/lib/i32;
Move to directory binary icc (/opt/intel/Compiler/11.1/064/bin/ (ia32 or intel64))
./icpc -fPIC -ansi -shared-intel -axSSSE3 -Os -fast -openmp -openmp-lib=compat -openmp-report -march=core2 -mtune=core2 -fomit-frame-pointer source.cc -o binary_result
if problem persisting repeat new install icc compiler better.
Kind regards
thouraya87
hello
After making the command that you have mentioned, I have
ipo: remark #11001: performing single-file optimizations
ipo: remark #11005: generating object file /tmp/ipo_icpc2EGCGU.o
mmv2.c(19): (col. 1) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
./mmv2
I have the execution well without the warnings
I reinstall or no?
thank you very much
aazue
Hi
I reinstall or no?
no same it work now ..
Now make or search well sample for take practice.
good luck
Kind regards
thouraya87
Hello
Thank you very much
