Hello Everyone,
I have installed the Parallel Studio (parallel_studio_xe_2011_sp1_update2_intel64_setup.exe) on my Linux box. The compilation seems 2-3 time slower compared to intel 11.1 compiler. I tried to perform the test on "Hello World" Program and see the same behaviour.
Santosh
Hi Sergey,
I have installed the IPS SP3 Update3 yesterday and with that compilation is extremely fast but I am concern about the IPS SP3 Update2, actually all our builds are being created with the IPS SP3 Update2. Can you please confirm if there is any compilation time issue with Update2
Details:
Installer: parallel_studio_xe_2011_sp1_update2_intel64_setup.exe ( IPS SP3 Update2)
Version Info:
spsingh@punsuppalalnx.ansys.com[262] icc --version
icc (ICC) 12.1.3 20120212
Copyright (C) 1985-2012 Intel Corporation. All rights reserved
Machine Info:
processor : 31
vendor_id : GenuineIntel
cpu family : 6
model : 45
model name : Intel(R) Xeon(R) CPU E5-2665 0 @ 2.40GHz
stepping : 7
cpu MHz : 1200.000
cache size : 20480 KB
physical id : 1
siblings : 16
core id : 7
cpu cores : 8
apicid : 47
initial apicid : 47
fpu : yes
fpu_exception : yes
cpuid level : 13
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 apic mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc arch_perfmon pebs bts rep_good xtopology nonstop_tsc aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx smx est tm2 ssse3 cx16 xtpr pdcm dca sse4_1 sse4_2 x2apic popcnt aes xsave avx lahf_lm ida arat epb xsaveopt pln pts dts tpr_shadow vnmi flexpriority ept vpid
bogomips : 4791.12
clflush size : 64
cache_alignment : 64
address sizes : 46 bits physical, 48 bits virtual
Please let me know if you need any details from my side.
Santosh
These are the details
Hi Georg,
That was just by mistake, I mean to say ""parallel_studio_xe_2011_sp1_update2_intel64.tgz". actually I am using floatinng license. I have installed "parallel_studio_xe_2011_sp1_update3_intel64.tgz and poining it the same same license server and it is compiling very fast (2 -3 time faster). I am fine to move to update3 but before I just want confirmation if there was real issue with update2.
Santosh
