I've found a problem when passing parameters from VS env. to IntelCC (however it looks like VS bug)
I had a problem with compiling project using BOOST + STL - I got all the time that compilation options are not same for both libraries. To make a long story short one - __STL_DEBUG preprocessor had to be used.
I did use one in Preprocessor settings from within VS GUI - having the 'command line' looks like:
/c /Od /D "WIN32" /D "_DEBUG" /D "_WINDOWS" /D "__STL_DEBUG" /D "_DLL_VERSION" /D "_WINDLL" /D "_MBCS" /D "_VC80_UPGRADE=0x0710" /EHsc /MTd /Zp4 /GS /fp:fast /Fo".\Debug/" /W3 /nologo /ZI
So - as you can see - VS by default put preprocessor into ""
And ... it was not working, however adding manually into command line __STL_DEBUG did solve the problem:
/c /Od /D "WIN32" /D "_DEBUG" /D "_WINDOWS" /D "_DLL_VERSION" /D "_WINDLL" /D "_MBCS" /D "_VC80_UPGRADE=0x0710" /EHsc /MTd /Zp4 /GS /fp:fast /Fo".\Debug/" /W3 /nologo /ZI /D __STL_DEBUG
Did try invoking Intelcc from the command line and indeed - no difference between /D "__STL_DEBUG" and /D __STL_DEBUG
Wired.....
be carefull - maybe you're also wasting your time due to such problems..
Stan
Thanks for the posting.
I'll check it as well to make sure it's not Intel IDE integration related.
Jennifer
Jennifer
Stan,
You haven't specified which compiler and MSVC version you use.
By the way, you can try replacing icl.exe with a small program (you can write it in less than 2 minutes) which just dumps command line arguments to a file and exits so you can determine for sure whether compiler is getting the option or not.
I'm not sure how I did it, but at one point, my .vcproj file contains:
PreprocessorDefinitions="TEST_1;TEST_2; _TEST_3"
So build failed. Once I cleaned it up, all is fine. Now I couldn't reproduce.
Quoting - Jennifer Jiang (Intel)
Perhaps you pressed the Enter key twice? 0x0A is a hex-code for new line character and &# seems to be a way to represent it in HTML/XML (escaped text). Perhaps project conversion tool mistakenly tries to escape the string?
Quoting - Igor Levicki
This is VS 2005 + Intel 11.0.66
I'll replace compiler by the batch to examine passed parameters - that's a good point - thanks. I don't imagine - I've put any special char - but on the other hand - everything is possible..
Stan
