Hello!
After several tests I'm ready to report a bug, but not sure if the bug related to mysql or icc.. The problem is thatphp 5.3.3 compiling crashes after compiling mysql 5.1.50. There is no any crashes on php 5.3.3 after compiling previous mysql 5.1.49..
/usr/local/mysql//include/mysql/my_global.h(626): catastrophic error: could not open source file "my_compiler.h"
#include
compilation aborted for /root/src/php-5.3.3/ext/mysqli/mysqli.c (code 4)
make: *** [ext/mysqli/mysqli.lo] Error 1
My system:
CentOS 5.5 64-bit
Intel C++ Compiler for Linux 11.1.073 intel64
2Gb RAM,Intel Pentium Processor E2160
Is that an ICC problem? Or should I go to the mysql support?
By all means, this seems not a bug in either (mysql or ICC).
Did you followANY one of these which fixes the problem:--
1) This is easily fixed. After running 'make install' during the source installation process,
simply fire off the following command:
cp /usr/local/src/mysql-5.1.50/include/my_compiler.h
/usr/local/mysql/include/mysql/my_compiler.h
PHP 5.3.3 will now build the mysqli module with MySQL 5.1.50 from source.
2) ./configure --with-mysql=mysqlnd --with-mysqli=mysqlnd --with-pdo-mysql=mysqlnd
For more details on the exact bug, take a look at :--
http://bugs.mysql.com/bug.php?id=56556
Please let me know if theese work on your CentOS as well..
Ok, thank you for the answer! I've tried to run the command (below) before running 'make' and compilation finished without any problem :
cp /root/src/mysql-5.1.50/include/my_compiler.h /usr/local/mysql/include/mysql/my_compiler.h
It is a really bug of mysql 5.1.50 and will be fixed in 5.1.51
Glad to know it fixed the problem.
