This is what i am trying to achieve ::
I got eflags value into a context structure "ctx" using GetThreadContext Microsoft API
Now my intention is to set the eflags value in this structure to current thread
This is how i am doing
/*I got to know that we cannot directly modify eflags register,so....
1. I am getting the value in ctx structure to Eax register
2. Pushing the value in Eax register to stack
3. Poping the recently pushed value into eflags register */
mov eax, dword ptr [ctx+0x044]; // as eflags is 32-bit I am using eax instead of rax
push eax;
popfd;
when i try to compile this, i am seeing below compile error
C:\1\stacktracing.c(81): (col. 5) error #13252: Unsupported instruction form in asm instruction push.
C:\1\stacktracing.c(82): (col. 5) error #13250: Opcode POPFD unsupported by architecture in asm instruction popfd.
1. Can't we push 32-bit eax to a stack in 64-bit machine ....if yes, any alternative?
2. Can't we use popfd in 64-bit machine ?
Thanks & Regards
Naveen
Let me know if i am in the right path -- reg what i want to achieve or is there any drawback in the way i am doing
I use icl of below version
Intel(R) C++ Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 12.0.5.229 Build 20120731
Copyright (C) 1985-2011 Intel Corporation. All rights reserved.
icl: command line error: no files specified; for help type "icl /help"
No. Just as you cannot do push ax or pop ax in 32-bit ASM, and you cannot do push al or pop al in 16-bit ASM. The primary reason is that in 64-bit mode the stack has to be aligned on 8-byte boundaries.
Secondly, why are you bothering with eflags in 64-bit mode, instead of using rflags?
For definitive answers on these and related questions, refer to the Intel instruction set reference manuals:
http://download.intel.com/products/processor/manual/253666.pdf
http://download.intel.com/products/processor/manual/253667.pdf
I couldn't get what you mean by "Do you use inline assembler in a C/C++ source file?"
I am writing assembly as below
_asm
//First restore eflags
//mov eflags, dword ptr [ctx+0x044];
push Rax;
popfq;
mov Rax,qword ptr [ctx+0x078] ;
mov Rcx,qword ptr [ctx+0x080];
mov Rdx,qword ptr [ctx+0x088] ;
mov Rbx,qword ptr [ctx+0x090];
mov Rsp,qword ptr [ctx+0x098] ;
mov Rbp,qword ptr [ctx+0x0a0];
mov Rsi,qword ptr [ctx+0x0a8] ;
mov Rdi,qword ptr [ctx+0x0b0];
mov R8,qword ptr [ctx+0x0b8] ;
mov R9,qword ptr [ctx+0x0c0];
mov R10,qword ptr [ctx+0x0c8] ;
mov R11,qword ptr [ctx+0x0d0];
mov R12,qword ptr [ctx+0x0d8] ;
mov R13,qword ptr [ctx+0x0e0];
mov R14,qword ptr [ctx+0x0e8] ;
mov R15,qword ptr [ctx+0x0f0];
mov cs, WORD ptr [ctx+0x038];
mov ds, WORD ptr [ctx+0x03a];
mov es, WORD ptr [ctx+0x03c];
mov fs, WORD ptr [ctx+0x03e];
mov gs, WORD ptr [ctx+0x040];
mov ss, WORD ptr [ctx+0x042];
//mov Rip,qword ptr [ctx+0x0f8];
jmp qword ptr [ctx+0x0f8];
done:
All general purpose registers are getting updated properly...but i am seeing issue with eflags and segment registers
I generated a .i file and saw that CONTEXT structure in win64 is having EFLAGS in it....that is why i am trying to restore eflags inplace of rflags
OK. I am using inline assemby in "**.c" file
In my first post....you can see the file name in the error messages i posted.
Naveen,
Jim Dempsey
Additional link: http://www.codegurus.be/codegurus/programming/riprelativeaddressing_en.htm
Jim Dempsey
For corectness, it should be
Sergey Kostrov wrote:
_asm
// First restore eflags
// mov rflags, qword ptr [ ctx+0x044 ]
mov rax, qword ptr [ ctx+0x044 ]push Rax
popfq...
...since upper half of rflags (reserved - do not use) is filled with leftover trash in upper half of RAX.
Indeed s/he should use pushfq/popfq pair, since there is no such instruction in long mode such as pushfd nor popfd. If there were such instructions, it would lead to stack pointer mis-alignment.
Take a look at these two error messages:
>>...1. These two messages are very confusing and Naveen thinks that these two instructions are not supported on a 64-bit platform. Try to use the test case I've posted with Microsoft 64-bit C++ compiler and you will see similar error messages.
IMO, they are not confusing at all. It clearly states that "popfd" is not supported on amd64/IA-64 architecture running in 64-bit mode, which is indeed truth (see reference manual from Intel or AMD). But there is popfq for this purpose - others said this as well in this forum topic.
2. Then, we're trying to understand what is wrong with compilation of Naveen's codes with inline assembler because something else is really wrong. Microsoft's 64-bit C++ compiler doesn't support inline assembles at all (!) for 64-bit platforms.
Yes, MS compiler has not implemented 64-bit inline assembler. I know this fact, though, I am unable to compile the test case right now.
Intel 64-bit C++ compiler supports inline assembler for 64-bit platforms and I verified it with version 13. But, Naveen is using version 12 and I don't have any chance to verify it. It is possible that version 12 doesn't support it. So, If you have Intel 64-bit C++ compiler version 12 simply try to compile a test
Sorry, I missed the fact Naveen is using ICC 12. I was thinking about ICC 13, sorry for the noise. I don't have this version at the hand as well. And I will not in near future as well :-( .
case I've posted. All the rest things, I mean execution at run-time, is Naveen's assignment.
Of course.
Good luck Naveen. I hope ICC 12 has correctly implemented pushfq/popfq in 64-bit mode without a bug.
Once again, I am sorry for confusion.
To be more precise, in amd64 instruction set, there are no such instructions as POPFD nor PUSHFD at all.
Initially when i posted this...i used popfd......with this i saw compile error
Later i myself changed to popfq, with this compilation is going fine......but
1. eflags value is not getting updated
2. when i am executing segment registers related assembly, i am seeing this error message
(ccc.1464): Illegal instruction - code c000001d (!!! second chance !!!)
stacktracing!PrintStackTrc+0x2e7:
00000001`3fd4132d 668e0dc47c0000 mov cs,word ptr [stacktracing!ctx+0x38 (00000001`3fd48ff8)] ds:00000001`3fd48ff8=0033
regarding [1.] are you sure you are restoring the CORRECT value stored before? make your checks in debugger.
[2.] in user mode (i.e. your application is application (ring 3), not kernel driver (ring 0 - supervisor), as far as I know you are not able to modify segment registers. Even more, you need not to restore them at all in this case, since they are always constant for given program instance thru its life, and they are not volatile - even OS will not change it. and *IF* OS wanted change them (but no OS do such hacks), it will use its own mechanisms to do it, via modifying TSS (task state segment).
