Couldn't find a bug tracker so...
icc chokes on this line (because of the && that gcc and msvc have no problem with) with aninternal error: 0_1506
#pragma omp parallel for private(y) if(!nqd->preview && img->y*img->x > 16384) schedule(guided)Had to do this to workaround the problem:
#ifdef __INTEL_COMPILER
#pragma omp parallel for private(y) if(!nqd->preview) schedule(guided)
#else
#endif
icc (ICC) 12.0.0 20101006IA-32
Ubuntu 10.10 x86_32
Please submit a bug report with a working example on your premier.intel.com account. We could hope that someone might try to reproduce this, but it might be difficult without the actual example.
How about:
bool doGuided = (!nqd->preview && img->y*img->x > 16384);
#pragma omp parallel for private(y) if(doGuided) schedule(guided)
Jim Dempsey
Jim Dempsey
Don't think I have a premium account being a non-commercial 'free' user but I'll check.
The actual file this shows up in (don't know what's up with their security cert):
Also the other tools don't seem to like Blender too much so no staticanalysisor thread/memory checking. Totally separate issue I know but seem like a good test case since I've run it through llvm/clang tools with no problems before.
If you didn't open an account, you can do so at https://registrationcenter.intel.com using the license key (embedded in the name of your license file.
I've seen problems with inclusion of compound syntax in omp clauses before; I agree they should be reported and maybe fixed.
I duplicated the internal error with the test below on Windowis. I'll file a bug report for it.
When it's fixed, I'll let you know.
Thanks for reporting the issue.
Jennifer
[bash]typedef struct { bool preview; bool isImage; } strNQD; typedef struct { int x; int y; } strIMG; void foo(strNQD* nqd, strIMG* img) { int y; #ifdef 0 #pragma omp parallel for private(y) if(!nqd->preview) schedule(guided) // works #else #pragma omp parallel for private(y) if(!nqd->preview && img->y*img->x > 16384) schedule(guided) #endif for (y = 0; y < 16355; y++) img->y = y+img->x; } [/bash]
Jennifer
The fix for your issue was included in the Intel Parallel Studio/Composer 2011
Update 3. I tried your testcase with the actual Update 4 and it worked
for me.
Alexander
Alexander
Topic Options
