Intel® C++ Compiler
7833 Discussions
#pragma compound statement -- internal error: 0_1506
dan_e
Couldn't find a bug tracker so...
icc chokes on this line (because of the && that gcc and msvc have no problem with) with aninternal error: 0_1506
#pragma omp parallel for private(y) if(!nqd->preview && img->y*img->x > 16384) schedule(guided)
Had to do this to workaround the problem:
#ifdef __INTEL_COMPILER
#pragma omp parallel for private(y) if(!nqd->preview) schedule(guided)
#else
#endif
icc (ICC) 12.0.0 20101006IA-32
Ubuntu 10.10 x86_32
TimP
Black Belt
Please submit a bug report with a working example on your premier.intel.com account. We could hope that someone might try to reproduce this, but it might be difficult without the actual example.
jimdempseyatthecove
Black Belt
How about:
bool doGuided = (!nqd->preview && img->y*img->x > 16384);
#pragma omp parallel for private(y) if(doGuided) schedule(guided)
Jim Dempsey
dan_e
Don't think I have a premium account being a non-commercial 'free' user but I'll check.
The actual file this shows up in (don't know what's up with their security cert):
Also the other tools don't seem to like Blender too much so no staticanalysisor thread/memory checking. Totally separate issue I know but seem like a good test case since I've run it through llvm/clang tools with no problems before.
TimP
Black Belt
If you didn't open an account, you can do so at https://registrationcenter.intel.com using the license key (embedded in the name of your license file.
I've seen problems with inclusion of compound syntax in omp clauses before; I agree they should be reported and maybe fixed.
JenniferJ
I duplicated the internal error with the test below on Windowis. I'll file a bug report for it.
[bash]typedef struct {
	bool preview;
	bool isImage;
} strNQD;
typedef struct {
	int x;
	int y;
} strIMG;
void foo(strNQD* nqd, strIMG* img)
	int y;
#ifdef 0
   #pragma omp parallel for private(y) if(!nqd->preview) schedule(guided) // works
#else
#endif
	for (y = 0; y < 16355; y++)
		img->y = y+img->x;
} [/bash]
When it's fixed, I'll let you know.
Thanks for reporting the issue.
Jennifer
Alexander_W_Intel
The fix for your issue was included in the Intel Parallel Studio/Composer 2011 Update 3. I tried your testcase with the actual Update 4 and it worked for me.
Alexander
