Intel® C++ Compiler
pragma offload target(gfx) error
Mathieu_D
I'm trying to write my first program using pragma offload target(gfx). I tried the exemple from this page, replacing mic with gfx :
subr.c
void subr()
main.c
int main()
  #pragma offload target(gfx)
  subr();
The output :
$ icc -c -qoffload-attribute-target=gfx subr.c
$ icc subr.o main.c
main.c(4): error: function "subr" called in offload region must have been declared with compatible "target" attribute
    subr();
main.c(4): error: offload target(gfx) or omp target pragma is not followed by a parallel loop
    subr();
compilation aborted for main.c (code 2)
How can I adapt this example to target "gfx" ?
If it helps, I have icc 17.0.1, from Intel Parallel Studio XE 2017 Cluster edition, and a Broadwell-U GPU (Iris pro 6200).
Mathieu
Yuan_C_Intel
Hi, Mathieu
The offloaded code on GPU need to run in parallel and vectorizable. The supported programming model in offloaded code for graphics are followings:
  • A Subset of Intel® Cilk™ Plus Language Extensions: The compiler supports the _Cilk_for, _Thread_group and__thread_group_local keywords to specify parallelism in offloaded code and thread group local data, as well as #pragma offload syntax to enable offload.
  • API-based Offload: In this model, you don't use any special syntax for initiating an offload, such as #pragma offload or #pragma omp target. Instead, you express data setup and offload using special API functions implemented in the Intel® Graphics Technology offload runtime.
You can download and try our graphics processor samples as a start: Intel® C++ Compiler - Samples for Intel® Graphics Technology
Please also make sure you have read the getting started guide for all the requisites:
https://software.intel.com/en-us/articles/getting-started-with-compute-offload-to-intelr-graphics-technology
Hope this helps.
Mathieu_D
Hi Yolanda,
Thank you for your answer, the samples are very useful.
Mathieu
