Intel® C++ Compiler
#pragma omp cancel for compilation error
AndrewC
New Contributor III
The following code fails to compile with
error : cancel for must be closely nested in a for region.
I am at a loss here, as this code seems to follow the example in OpenMP 4.0 examples PDF
void causes_an_exception()
	throw std::logic_error("exception");
void example()
	std::exception *ex = NULL;
	bool cancelled = false, failed = false;
	int N = 100000;
#pragma omp parallel for
	for (int i = 0; i < N; i++) {
		// no 'if' that prevents compiler optimizations
		try {
			causes_an_exception();
		catch (std::exception *e) {
			// still must remember exception for later handling
#pragma omp atomic write
			ex = e;
			// cancel worksharing construct
Andrey_C_Intel1
"It seems to cancel the thread running when the exception is thrown, but the other threads keep running to completion."
This is required by the OpenMP specification.  A thread can only be cancelled at cancellation points (e.g. "#pragma omp cancellation point for").  Once other threads do not encounter any cancellation point they are bound to run to completion. If you want other threads to early react on cancellation you need to insert cancellation point(s) where threads can check for cancellation.
Olga_M_Intel
According to OpenMP specification "the cancel construct must be closely nested inside an OpenMP construct that matches the type specified in construct-type-clause of the cancel construct". So, the error seems to be correct but the example probably not.
AndrewC
New Contributor III
The OpenMP construct is a parallel for and the omp cancel statement is "cancel for" which matches the "for" construct
So as far as I am concerned this is a compiler bug unless an OpenMP guru can convince me otherwise.
If I make a small change to the code, adding a parallel region block I can get it to compile
void example()
	int N = 100000;
#pragma omp for
			try {
				causes_another_exception();
				ex = e;
AndrewC
New Contributor III
When I implement the above pattern in my code (not the trivial example above)
I get ( ICC 18.0 Update 2)
1>": : error : ** The compiler has encountered an unexpected problem.
1>** Segmentation violation signal raised. **
1>Access violation or stack overflow. Please contact Intel Support for assistance.
AndrewC
New Contributor III
Using GCC 6.3.1 gives the following message on my first example
warning: ‘#pragma omp cancel for’ inside ‘nowait’ for construct
AndrewC
New Contributor III
The following code causes an error in the Intel Compiller 18.0 Update 2
Windows 64/Release build
#include <stdexcept>
#include <list>
#include <vector>
#include <iostream>
#include <omp.h>
void causes_another_exception(int i)
	if(i==10){
	}else{
#pragma omp critical
		std::cout << "thread:" << omp_get_thread_num() << " i:" << i << std::endl;
void example()
	std::exception ex ;
	int N = 500;
#pragma omp for
			try {
				causes_another_exception(i);
			catch (std::exception &e) {
				std::cout << "thread " << omp_get_thread_num() << " caught exception:" << i << std::endl;
				ex = e;
int main()
	char *str=getenv("OMP_CANCELLATION");
    if(str){
		std::cout << "OMP_CANCELLATION:"<<str << std::endl;
	example();
AndrewC
New Contributor III
I have created a support ticket 03380632
Andrey_C_Intel1
Thank you for reporting the bug (actually two bugs, - one is the mistake in "illegal" constructs nesting, another one is the internal compiler error).
Andrey
AndrewC
New Contributor III
I did some tests using GCC 6.3.1
It complains about my first example with
// GCC test.cpp:38:23: warning: ‘#pragma omp cancel for’ inside ‘nowait’ for construct
There is some argument on stack exchange about this.
Interestingly, using GCC 6.3.1, although it can compile and build the final example, I cannot get "omp cancel for" to work as expected even with OMP_CANCELLATION=true. It seems to cancel the thread running when the exception is thrown, but the other threads keep running to completion.
Andrey_C_Intel1
AndrewC
New Contributor III
Ok, thinking about that, it makes sense.
AndrewC
New Contributor III
Something like below works as expected.
I think the requirement for OMP_CANCELLATION to be set via as an env variable makes the whole idea a bit useless in the real world.
void example()
	std::exception ex ;
	bool cancelled = false;
	int N = 500;
#pragma omp for
			if(cancelled){
			try {
				ex = e;
				cancelled=true;
