Using the following:
#pragma push 0#include "external_header.hpp"#pragma pop
Results in the error:
main.cpp(49): error #1029: warning level out of range, expected value between 1 and 4
#pragma warning push 0
However, the microsoft compiler allows this disabling all warnings by setting all warning levels to zero. Is there any plans to support this in the intel compiler?
It is a very useful feature in the microsoft compiler because virtually no external headers pass the highest warning level on the microsoft compiler (even their own Dinkumware stdlib) so disabling all warnings for an external header helps.
I can't seem to get the following to work:
#pragma push#pragma warning disable [0-9]+ {[0-9]+...}#include "external_header.hpp"#pragma pop
