Intel® C++ Compiler
problem with c++ instalation
mahdi109
Dear all,
i have a problem with ifort instalation,
i install BOTH intel fortran and intel c++ compilers.
when i typing "sudo /opt/intel/bin/link_install.sh -s" after installing for cheking,
in my terminal some statements is "not present" What I do? (i use SUSE Linux Enterprise Server 10 SP2 x86_64)
guilan@linux-kair:~> sudo /opt/intel/bin/link_install.sh -s
ICP12_REPORT()
INTEL_BIN_DIR=/opt/intel/bin (exists)
INTEL_COMPOSERXE_2011_DIR=/
opt/intel/composer_xe_2011_sp1 (exists)
INTEL_COMPOSERXE_2011_BIN_DIR=/opt/intel/composer_xe_2011_sp1/bin (exists)
INTEL_COMPOSERXE_DIR=/opt/intel/composerxe (exists)
INTEL_COMPOSERXE_BIN_SC=/opt/intel/composer_xe_2011_sp1/bin/sourcechecker (exists)
INTEL_COMPOSERXE_2011_PKG_BIN_DIR=/opt/intel/composer_xe_2011_sp1/pkg_bin (exists)
INTEL_COMPOSERXE_2011_LIB_DIR=/opt/intel/composer_xe_2011_sp1/lib (exists)
INTEL_COMPOSERXE_2011_INCLUDE_DIR=/opt/intel/composer_xe_2011_sp1/include (exists)
INTEL_COMPOSERXE_2011_MAN_DIR=/opt/intel/composer_xe_2011_sp1/man (exists)
INTEL_COMPOSERXE_2011_TBB_DIR=/opt/intel/composer_xe_2011_sp1/tbb (not present)
INTEL_COMPOSERXE_2011_TBB_DIR=/opt/intel/composer_xe_2011_sp1/arbb (not present)
INTEL_COMPOSERXE_2011_MKL_DIR=/opt/intel/composer_xe_2011_sp1/mkl (exists)
INTEL_COMPOSERXE_2011_IPP_DIR=/opt/intel/composer_xe_2011_sp1/ipp (exists)
INTEL_COMPOSERXE_2011_DEBUGGER_DIR=/opt/intel/composer_xe_2011_sp1/debugger (exists)
INTEL_COMPOSERXE_2011_ECLIPSE_SUPPORT_DIR=/opt/intel/composer_xe_2011_sp1/eclipse_support (exists)
INTEL_COMPOSERXE_2011_DOCUMENTATION_DIR=/opt/intel/composer_xe_2011_sp1/Documentation (exists)
INTEL_COMPOSERXE_2011_SAMPLES_DIR=/opt/intel/composer_xe_2011_sp1/Samples (exists)
INTEL_LIB_DIR=/opt/intel/lib (exists)
INTEL_INCLUDE_DIR=/opt/intel/include (exists)
INTEL_MAN_DIR=/opt/intel/man (exists)
INTEL_IPP_DIR=/opt/intel/ipp (not present)
INTEL_IPP_DIR=/opt/intel/arbb (not present)
INTEL_MKL_DIR=/opt/intel/mkl (exists)
INTEL_TBB_DIR=/opt/intel/tbb (exists)
thank you,
Om_S_Intel
By default tbb and ipp are installed when installing Intel C++ Composer XE 2011 sp1. The compiler will work if you use the following command:
$source /opt/intel/bin/compilervars.sh intel64
The Arbb is not yet part of the Intel compiler.
Om
Intel compiler support
mahdi109
thank you,
i do that,
but i have that error, now.
also i do this :
$ source /opt/intel/bin/compilervars.csh intel64
it display this error:
bash: /opt/intel/bin/compilervars.csh intel64: line 36: syntax error: unexpected end of file
do you think this error is no mather??? what should i do?
Om_S_Intel
It looks that the compiler is not installed properly. Could you please uninstall the compiler and reinstall it?
TimP
Black Belt
If you're running bash, you need the bash compatible version of that script (.sh, not .csh).
