Intel® C++ Compiler
problem with enviroment variables
shbk
i use ubuntu 10.10
intel c++ compiler ia32 was successful installed,
but when i try to set enviroment variables i receive errors:
root@sh:/opt/intel/bin# ./iccvars.sh ia32
/opt/intel/composerxe-2011/tbb/bin/tbbvars.sh: 38: [[: not found
/opt/intel/composerxe-2011/mkl/bin/mklvars.sh: 12: Bad substitution
may you give me some tips?
TimP
You must source the environment script, not run it as a shell script.
You shouldn't need to source all the individual scripts; they are meant to be run from the top level.
If you're running under tcsh or some other cshell compatible shell, simply change to the compilervars.csh
source /opt/intel/composerxe-2011/bin/compilervars.csh ia32
(or iccvars.csh, if that's what's present)
shbk
well, csh isn't my script , my script is .sh, i see this error
./iccvars.csh ia32
./iccvars.csh: 36: syntax error: unexpected end of file
i have moved to the source /opt/intel/composerxe-2011/bin/, what should i type there and where?
and what does source mean?
shbk
may be, should i something write in compilervars.sh ?
but i don't know what exactly
#!/bin/sh
# Copyright (C) 1985-2010 Intel Corporation. All rights reserved.
# The information and source code contained herein is the exclusive property
# of Intel Corporation and may not be disclosed, examined, or reproduced in
# whole or in part without explicit written authorization from the Company.
PROD_DIR=/opt/intel/composerxe-2011
if [ "$1" != "ia32" -a "$1" != "intel64" ]; then
echo "ERROR: Unknown switch '$1'. Accepted values: ia32, intel64"
return 1;
fi
if [ -e $PROD_DIR/pkg_bin/idbvars.sh ]; then
. $PROD_DIR/pkg_bin/idbvars.sh $1
fi
if [ -e $PROD_DIR/tbb/bin/tbbvars.sh ]; then
. $PROD_DIR/tbb/bin/tbbvars.sh $1
fi
if [ -e $PROD_DIR/mkl/bin/mklvars.sh ]; then
. $PROD_DIR/mkl/bin/mklvars.sh $1 $2
fi
if [ -e $PROD_DIR/ipp/bin/ippvars.sh ]; then
. $PROD_DIR/ipp/bin/ippvars.sh $1
fi
if [ -e $PROD_DIR/pkg_bin/compilervars_arch.sh ]; then
. $PROD_DIR/pkg_bin/compilervars_arch.sh $1
fi
Mark_S_Intel1
Actually both iccvars.sh and compilervars.sh set the same environment variables. You should be able to set the environment variables by doing:
source /opt/intel/composerxe-2011/bin/iccvarsh.sh OR
source /opt/intel/composerxe-2011/bin/compilervars.sh
Make sure the ttb and mkl directories referenced in the original errors you were getting do exist. They should not be needed if you are not going to use tbb andmkl libraries. So you should be able to use the compiler (e.g. icc -c file.c)after sourcing the above scripts even if you get errors abouttbb and mkl environmentsetting.
--mark
shbk
i don't know what i do wrong. i want to use intel compiler, but i can't solve this problem. my teachers in the university don't know anything about intel compiler. i don't know anybody who can help except this forum
Mark_S_Intel1
Sorry, I missed ia32 argument, the command should be:
source /opt/intel/composerxe-2011/bin/iccvars.sh ia32
Do you still get the same errors when you execute the above command?
Do the tbb and mkl direcotiries exist in your installation?
Does doing "icc -V" command work after executing the above command?
--mark
shbk
thank you. i don't know what i'll do without your help . it was very simple. i couldn't understand meaning translate's word 'source'. but i should just type this command.
thanks guys
Mark_S_Intel1
Looks like your issue is resolved. Just for your information, we currently support Ubuntu 10.04. But usually, a minor version update should not cause problems. You can find details at
http://software.intel.com/en-us/articles/using-intel-compilers-for-linux-with-ubuntu/
Ubuntu has a Long Term Support version where they will support it for a long time. This was 10.04. 10.10 is a update release and will not have long term support, meaning it will be superceded by the next update or LTS release and dropped.
Ive heard quite a few posts on the net about 10.10 problems and general unhappiness with this release. Would not surprise me if something was broken.
--mark
shbk
o no, in my case all is the well with Ubuntu 10.10
thank you for support
"Does doing "icc -V" command work after executing the above command?"-
Yes, it's work
Swapnil_J_
Hello Friends, I am New in intel composer_xe, I have Install intelSDK and I am tring to set envornment vaiable of IntelSDK my installation path is : /opt/intel/composer_xe_2013/ when I am executing following command: root@swapnil-lp:/opt/intel/composer_xe_2013/bin# ./compilervars.sh intel64 ./compilervars.sh: 24: /opt/intel/composer_xe_2013/tbb/bin/tbbvars.sh: [[: not found ./compilervars.sh: 39: /opt/intel/composer_xe_2013/ipp/bin/ippvars.sh: [[: not found I got such error I am using Ubuntu12.04 I have tried all above solution. But still iam facing this problem.
TimP
These environment scripts are to be sourced, not run as a script: source /opt/intel/composer_xe_2013/bin/compilervars.sh intel64 The compilervars script sets up the tbb and ipp, if they were installed along with icc.
Swapnil_J_
Hi TimP (Intel) My Installation path is /opt/intel/ but still my problem waiting for solution: swapnil@swapnil-lp:~$ /opt/intel/composer_xe_2013/bin/compilervars.sh intel64 /opt/intel/composer_xe_2013/bin/compilervars.sh: 24: /opt/intel/composer_xe_2013/tbb/bin/tbbvars.sh: [[: not found /opt/intel/composer_xe_2013/bin/compilervars.sh: 39: /opt/intel/composer_xe_2013/ipp/bin/ippvars.sh: [[: not found swapnil@swapnil-lp:~$ cd /opt/intel/composer_xe_2013/tbb/bin/ swapnil@swapnil-lp:/opt/intel/composer_xe_2013/tbb/bin$ ls tbbvars.csh tbbvars.sh swapnil@swapnil-lp:/opt/intel/composer_xe_2013/tbb/bin$ cd /opt/intel/composer_xe_2013/ipp/bin/ swapnil@swapnil-lp:/opt/intel/composer_xe_2013/ipp/bin$ ls intel64 ippvars.csh ippvars.sh I have checked this two file they are present at specified location then why this happen. What I have to do to set compilervar? Is it file not found error or any thing else? Thanks!! :)
