Hi all,
I compiled a program wrote in C using Intel Compiler C 11.1.069 under 32 and 64 bits with Opensuse 11.2.
It runs perfectly under 32 bits, but when it runs under 64 bits when initialize variables appears "segment violation".
The compiler has defined the next includes:
/opt/intel/Compiler/11.1/069/include
/opt/intel/Compiler/11.1/069/include/intel64
/usr/include
/usr/local/include
/usr/lib64/gcc/x86_64-suse-linux/4.4/include
The program uses:
#include
#include
#include
#include
#include
#include
and the pointer that has problem is:
int **nSwitch;
nSwitch=(int **)malloc((nti+1)*sizeof(int));
for (i=0; i<=nti; i++)
nSwitch=(int *)malloc(6*sizeof(int));
for (i=1; i<=nti; i++)
for (j=1; j<=5; j++)
nSwitch=0;
I have no idea how to solve it.
/usr/include
/usr/local/include
The program uses:
#include
#include
#include
#include
#include
#include
int **nSwitch;
nSwitch
The excerpts you show aren't C. Compiler warnings might be more meaningful if you would change it to C. Even if you did write C, the Intel C++ forum might work better, if you have questions about icc.
Thanks you for your reply,
finally I found the problem. I changed the next line:
by:
nSwitch=(int **)malloc((nti+1)*sizeof(int*));
And now it works perfectly
by:
So this topic has gone for tutorial for new beginner. Thanks.
That the change from 'sizeof(int)' to 'sizeof(int *)' was all that was needed shows that the original program was written with the implicit assumption that integers and pointers had the same size. That assumption would be correct under (i) 16 bit MSDOS (ii) most versions of 32 bit Windows, Linux, Unix but not Linux-X64. It may be good to check what assumptions the program made regarding the sizes of 'int' and 'long'.
If you want to avoid nightmare porting from 32 to 64 bits you shouldn't use build-in type directily. What I usually do is to create a Class with my types like this:
class Types
public:
#ifdef WIN32
typedef unsigned __int64 uint64_t;
typedef signed __int64 int64_t;
#else
typedef unsigned long long uint64_t;
typedef signed long long int64_t;
#endif
typedef unsigned char uint8_t;
typedef signed char int8_t;
typedef unsigned short int uint16_t;
typedef signed short int int16_t;
typedef unsigned int uint32_t;
typedef signed int int32_t;
typedef uint32_t tag_t;
typedef tag_t moduleTag_t;
typedef tag_t fieldTag_t;
typedef uint32_t lenght_t;
typedef uint8_t* buffer_t;
static void CheckTypes();
Types(void);
~Types(void);
And in the constructor, you can check that everything is like you belive, it not, change the class to adapt.
void Types::Types()
assert(1 == sizeof(uint8_t));
assert(1 == sizeof(int8_t));
assert(2 == sizeof(uint16_t));
assert(2 == sizeof(int16_t));
assert(4 == sizeof(uint32_t));
assert(4 == sizeof(int32_t));
assert(8 == sizeof(uint64_t));
assert(8 == sizeof(int64_t));
Of course you will need to change or add more check for you machine.
I hope this to be useful for you.
class Types
public:
#ifdef WIN32
#else
#endif
Types(void);
~Types(void);
void Types::Types()
