except for the below error. pinsrw is a valid assembly instruction why does it not compile?
thank you
this is the error
error: unsupported instruction form -- __asm pinsrw
#define _CALCULATE(number)
__asm mov edi, [eax]
__asm mov cx, word ptr [esi+edi]
__asm pinsrw xmm3, cx, shiftNr
__asm add edi, edx
__asm add eax, 4
__asm pinsrw xmm5, cx, shiftNr
If you believe that shiftNr is a constant, please post a compilable test case and I'll look at it some more.
Thanks!
Dale
void foo()
__asm pinsrw xmm3, ecx, 2
__asm add edi, edx
__asm add eax, 4
__asm pinsrw xmm5, ecx, 2
Then it works on both Linux and Windows. In the original form, assuming that "number" should really be shiftNr and instantiating the macro in a function, it fails on both Linux and Windows with the Intel compiler.
Dale
When I fix that, I see a difference in behavior between the MS compiler and the Intel compiler on windows. An issue is being submitted on that.
May I assume that the code you're porting from windows was built with the MS compiler? Is there any chance that using a function as above is a useful workaround (of course you can't pass in a parameter, which complicates things).
We'll update here when the issue as addressed.
Thanks!
Dale
Yes im converting the code from Visual studio 2005 -> intel compiler (ubuntu)
im using icpc -use-masm (to compile it)
#define _CALCULATE(shiftNr)
__asm add edi, edx
__asm add eax, 4
what is happening is i will be using this macro in this form in other parts of my code and yr correct that i am passing shiftNr as a constant and by doing it this way it works find in visual studio but gives the error
in linux and im using icpc -use-masm to compile it
__asm _CALCULATE(0x0)
Stupid question, but have you perhaps tried writing 0h instead of 0x0?
I should have posted some insight info I got earlier.
According to the Intel Software Developer's Manual, passing a 16-bit register to the PINSRW instruction is not valid.
should be rewritten as
pinsrw xmm3, ecx, shiftNr
In addition, it's strongly recommended that you change the 16-bit load instructions into zero extending loads. As written, this code suffers from a partial register stall. The machine implementation of PINSRW reads the full 32 bits of ECX even though only the lower 16 bits affect the result. This stall will severely affect the performance of this code. So instead of
mov cx, word ptr [esi + edi]
use
movzx ecx, word ptr [esi + edi]
