Intel® C++ Compiler
"ICL Intel® C++ Compiler XE 15.0" does not appear as option in Xcode 6
Jaime_Rios
I installed the trial version of the "Intel® Integrated Native Developer Experience 2015 Build Edition for OS X*" and found that the "ICL Intel® C++ Compiler XE 15.0" option is not available in Xcode 6 for compiling either C or C++ files.
Is this a known problem with the installer?
BTW, this thread was originally posted to both https://software.intel.com/en-us/forums/topic/535238 and https://software.intel.com/en-us/forums/topic/535084 by error. Sorry.
Alexander_W_Intel
Hi Jaime,
Xcode 6 does not seem to be supported according to the Release Notes. Xcode* 5.0 or 5.1 are the only official supported versions.
Alex
Jaime_Rios
Well, I hope they change their requirements soon since the adoption rate of 10.10 is higher than 10.9 and your average developer probably won't run Xcode 5 on 10.10.
Is there at least a workaround to this problem?
JenniferJ
The Intel Parallel Studio XE 2015 for OS X* update 1 supports the OS X 10.10 and XCode 6. You can download it from Intel Registration Center now.
Jennifer
JenniferJ
Sorry. Some clarification is needed.
The INDE Build Edition 2015 did not have the update 1, so OS X 10.10 & Xcode 6 are not yet supported. I will file a FR for it.
Jennifer
JenniferJ
Have you tried the work around posted here: https://software.intel.com/en-us/forums/topic/534599#comment-1803105 for now?
Although it is not yet supported, we do expect it to work. If you found any issues, please let us know.
Jennifer
Jaime_Rios
I took a look at the forum posts, but the directories that they mention in their product (Fortran) does not exist for INDE, so this appears to not be a solution.
Varvara_R_Intel
Hi Jaime,
Do you use Xcode 6.0 or Xcode 6.1? In case of Xcode 6.1 solution from the mentioned post should work for you (it's not Fortran specific).
Jaime_Rios
Hi Varvara,
As I had mentioned in the previous post, the directories mentioned in the other link do not exist for INDE for MacOS.
As a test, I created the folders and followed the steps described but still do not see the INDE compiler available under Xcode 6.1.
Jaime_Rios
I guess I should add some more info about my workstation configuration should someone try to duplicate what I am seeing:
Mac Pro (Early 2009)
Processor  2 x 2.93 GHz Quad-Core Intel Xeon
Memory  12 GB 1066 MHz DDR3 ECC
Software  OS X 10.9.5 (13F34)
Xcode Version 6.1 (6A1042b)
Varvara_R_Intel
Jaime,
I suppose that it may be just IDE support problem, not INDE. So, I thought you could try following steps:
  $ cd /Library/Application\ Support/Developer/      (this directory should exist on your Mac)
  $ sudo ln -s 6.0 6.1
and restart Xcode.
Jaime_Rios
Hi Valrvara,
I did the following steps, before you sent your reply:
$ sudo mkdir Developer      (this directory did not exist on my Mac)
$ cd Developer
Restarted Xcode; still could not see INDE compiler.
Nadezhda_D_Intel
Hello Jaime,
Could you please do the following:
1. Remove any links you made under /Library/Application Support/Developer yourself.
2. Run the INDE Build Edition installation package again.
3. Go to the dialog "Choose Install Environment":
  - select the option "Both command line and Xcode integration environment"
  - specify XCode install directory as the path to your XCode application (for example, /Applications/XCode.app).
3. Proceed with the installation.
4. When installation finishes, open the XCode and check for ICL Compiler option.
5. If it is still not available, send us the following:
 - output of the command "ls -la /Library/Application Support/Developer/"
 - the log files /var/log/system.log and /var/log/install.log
Nadya
Jaime_Rios
Here is the ls command results: jrios$ ls -la /Library/Application Support/Developer/ ls: /Library/Application: No such file or directory ls: Support/Developer/: No such file or directory
Nadezhda_D_Intel
Hello Jaime,
Thanks for the logs, they are helpful.  I see that you selected to integrate to XCode 6.1, but it is not supported in that release and that's why you do not see the compiler option in XCode. You will need to choose to integrate into lower XCode version (e.g. 6.0) and then follow the steps provided by Varvara above.
Jaime_Rios
Hi Nadezhida,
That is not going to be an available option for our development group so we will postpone considering the Intel compiler until a later date.
Thank you for your assistance.
