I am trying to compile the following code with icpc 16.0.3. And I am getting an internal assertion failure error:
Internal error: assertion failed at: "shared/cfe/edgcpfe/decl_spec.c", line 9392
Here is a minimal sample code to re-produce it (and also a workaround that I am currently using)
#include <iostream>
struct MiddleEarth
static constexpr char wizard[] = "Gandalf";
constexpr char MiddleEarth::wizard[];
template <typename T> struct Numenor
static constexpr char king[] = "pharazon";
/* static const char king[]; */ // workaround
constexpr char Numenor<T>::king[];
// workaround
/* template <typename T> */
/* const char Numenor<T>::king[] = "pharazon"; */
int main(int argc, char *argv[])
std::cout << "The greatest wizard is " << MiddleEarth::wizard << std::endl; // works
std::cout << "The greatest king is " << Numenor<int>::king << std::endl; // fails return 0;
I cannot reproduce this assertion failure with our latest 16.0 compiler.
I'm pretty sure this was fixed on 5/10 by the fix for DPD20038225 which allows a flexible array member type as a constexpr variable.
16.0 update 4 should available soon so please confirm that it is fixed.
Sorry for the inconvenience.
Judith,
The above issue is NOT present in 16.0.1, but is there in 16.0.2 and 16.0.3, so it looks like a regression.
Yes that is true. The cq number is DPD200382225 which was a regression from the fix for DPD200374125 which went into 16.0 on 12/7/2015.
