Intel® C++ Compiler
7877 Discussions
"a calling convention may not be followed by a nested declarator"
Darin_O_
I'm trying to specify a Windows 32 calling convention on a function whose name is a macro, similar to the following:
#define AddPrefix(x) (prefix##x)
#define function AddPrefix(function)
void __cdecl function( void );
int main( int argc, char **argv )
    return 0;
But the compiler raises the following error:
Intel(R) C++ Compiler XE for applications running on IA-32, Version 13.0.0.089 Build 20120731
Copyright (C) 1985-2012 Intel Corporation.  All rights reserved.
test.c
test.c(4): error: a calling convention may not be followed by a nested declarator
compilation aborted for test.c (code 2)
Is there anyway to specify a calling convention on declarations like this?  I need to include a header file with declarations as in my example above into a C file built with -Gz, which causes __stdcall to be the default.  Of course the shared library that matches the header was built without -Gz, so its exports are __cdecl.
Judith_W_Intel
the problem is the parenthesis around the function name, can you change the AddPrefix macro to:
#define AddPrefix(x) prefix##x
Judy
Darin_O_
Ok, I can work with that.
Darin
SergeyKostrov
Valued Contributor II
Judith, Thanks for the workaround. However, >>#define AddPrefix(x) ( prefix##x ) >>... I did a verification with a legacy C++ compiler Borland C++ version 5.5.1: ..\Test>bcc32.exe Main.cpp Borland C++ 5.5.1 for Win32 Copyright (c) 1993, 2000 Borland Main.cpp: Turbo Incremental Link 5.00 Copyright (c) 1997, 2000 Borland Main.cpp - 0 error(s), 0 warning(s) and it did Not have Any compilation errors with the test case provided. So, I consider it as a bug with Intel C++ compiler ( Also reproduced with a version 12.1.7.371 Build 20120928 ).
Judith_W_Intel
This is not a bug. On Windows we emulate the Microsoft compiler and they give an error too.
Judy
SergeyKostrov
[SergeyK] ...I consider it as a bug with Intel C++ compiler... ... [JudithW] ...This is not a bug... Judith, You're Not arguing with me. You're arguing with Borland. That is, with a leading ( in the past ) developer of high-performance ( very robust! ) C/C++ compilers. I use Borland C++ compiler for additional verifications that fundamental standards / specifications are properly supported and implemented. However, I'll do additional verification with MS Visual C++ v4.2 ( ~1995 year technology ) and let you know results.
SergeyKostrov
Judith, I did a quick verification with a Microsoft C++ compiler and I reproduced the compilation error: [ Microsoft C++ compiler version 14 - FAILED ] ... ..\Test>cl.exe Main.cpp Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86 Copyright (C) Microsoft Corporation. All rights reserved. Main.cpp Main.cpp(4) : error C2059: syntax error : '(' ... Here is another verification with a legacy C++ compiler Turbo C++: [ Turbo C++ compiler version 3 - SUCCESS ] ... ..\Test>tcc Main.cpp Turbo C++ Version 3.00 Copyright (c) 1992 Borland International main.cpp: Warning main.cpp 9: Parameter 'argc' is never used in function main(int,char * *) Warning main.cpp 9: Parameter 'argv' is never used in function main(int,char * *) Turbo Link Version 5.0 Copyright (c) 1992 Borland International Available memory 4124672 ... I see that Intel and Microsoft C++ compilers have bugs and I agree that as a workaround brackets need to be removed in the #define statement with ##.
Judith_W_Intel
Calling conventions are not part of the C or C++ standard. They are a Microsoft extension and thus Microsoft implemented the "de facto" standard.
SergeyKostrov
>>...Calling conventions are not part of the C or C++ standard... I'm not talking about _cdecl declaration. Extra brackets used around ( prefix##x ) create the Incompatibility problem with all the rest existing C++ compilers.
SergeyKostrov
Here are results of additional verification: Intel C++ v13.x - Failed ( VS 2008 ) Intel C++ v12.x - Failed ( VS 2005 ) Intel C++ v8.x - Failed ( VS 98 ) Microsoft C++ v17.x - Failed ( VS 2012 ) Microsoft C++ v16.x - Failed ( VS 2010 ) Microsoft C++ v15.x - Failed ( VS 2008 ) Microsoft C++ v14.x - Failed ( VS 2005 ) Microsoft C++ v12.x - Failed ( VS 98 ) MinGW v3.4.2 - Success ( integrated with VS 2005 ) Borland C++ v5.x - Success ( integrated with VS 2005 ) Turbo C++ v3.x - Failed ( integrated with VS 2005 ) Turbo C++ v1.x - Failed Also, Intel C++ compiler option /Qms0 ( disable Microsoft compatibility bugs ) doesn't make any difference.
