Hi Everyone,
I'm trying to compile a program that uses ADX. ICC version is:
$ icc --version icc (ICC) 17.0.4 20170411
The machine is a 6th gen Core i5, so ADX is available. ADX first appeared in 5th gen Core processors.
I'm using `-march=native` which should activate AVX2, BMI2 and other goodies like ADX on this particular machine. When I attempt to compile:
$ icc -Wall -O3 -march=native test.cxx -o test.exe test.cxx(14): error: #error directive: ADX is not available # error ADX is not available ^ ...
The error is triggered by the following in test.cxx:
#if !defined(__ADX__) # error ADX is not available #endif
Adding `-mcpu=corei5` does not help, and adding `-madx` results in an error.
I can't find local man pages. Searching online for the options pretty much sucks. I've found the ICC(1) man page at https://software.intel.com/sites/default/files/m/d/4/1/d/8/icc.txt, but it stops at Pentium 4's. Other than that, I'm getting useless hits for "intel icc enable adx".
How do I compile a program that uses ADX under ICC?
Thank you in advance.
Here are the preprocessor macros provided by ICC.
skylake:$ icc -march=core-avx2 -dM -E - </dev/null | sort #define __amd64 1 #define __amd64__ 1 #define __ATOMIC_ACQ_REL 4 #define __ATOMIC_ACQUIRE 2 #define __ATOMIC_CONSUME 1 #define __ATOMIC_HLE_ACQUIRE 65536 #define __ATOMIC_HLE_RELEASE 131072 #define __ATOMIC_RELAXED 0 #define __ATOMIC_RELEASE 3 #define __ATOMIC_SEQ_CST 5 #define __AVX__ 1 #define __AVX2__ 1 #define __AVX_I__ 1 #define __BIGGEST_ALIGNMENT__ 64 #define __BYTE_ORDER__ __ORDER_LITTLE_ENDIAN__ #define __CHAR16_TYPE__ unsigned short #define __CHAR32_TYPE__ unsigned int #define __CHAR_BIT__ 8 #define __cilk 200 #define __DATE__ "Aug 21 2017" #define __DBL_DECIMAL_DIG__ 17 #define __DBL_DENORM_MIN__ 4.9406564584124654e-324 #define __DBL_DIG__ 15 #define __DBL_EPSILON__ 2.2204460492503131e-16 #define __DBL_HAS_DENORM__ 1 #define __DBL_HAS_INFINITY__ 1 #define __DBL_HAS_QUIET_NAN__ 1 #define __DBL_MANT_DIG__ 53 #define __DBL_MAX_10_EXP__ 308 #define __DBL_MAX__ 1.7976931348623157e+308 #define __DBL_MAX_EXP__ 1024 #define __DBL_MIN_10_EXP__ -307 #define __DBL_MIN__ 2.2250738585072014e-308 #define __DBL_MIN_EXP__ -1021 #define __DEC128_EPSILON__ 1E-33DL #define __DEC128_MANT_DIG__ 34 #define __DEC128_MAX__ 9.999999999999999999999999999999999E6144DL #define __DEC128_MAX_EXP__ 6145 #define __DEC128_MIN__ 1E-6143DL #define __DEC128_MIN_EXP__ -6142 #define __DEC128_SUBNORMAL_MIN__ 0.000000000000000000000000000000001E-6143DL #define __DEC32_EPSILON__ 1E-6DF #define __DEC32_MANT_DIG__ 7 #define __DEC32_MAX__ 9.999999E96DF #define __DEC32_MAX_EXP__ 97 #define __DEC32_MIN__ 1E-95DF #define __DEC32_MIN_EXP__ -94 #define __DEC32_SUBNORMAL_MIN__ 0.000001E-95DF #define __DEC64_EPSILON__ 1E-15DD #define __DEC64_MANT_DIG__ 16 #define __DEC64_MAX__ 9.999999999999999E384DD #define __DEC64_MAX_EXP__ 385 #define __DEC64_MIN__ 1E-383DD #define __DEC64_MIN_EXP__ -382 #define __DEC64_SUBNORMAL_MIN__ 0.000000000000001E-383DD #define __DEC_EVAL_METHOD__ 2 #define __DECIMAL_BID_FORMAT__ 1 #define __DECIMAL_DIG__ 21 #define __EDG__ 1 #define __EDG_PTRDIFF_TYPE__ long #define __EDG_SIZE_TYPE__ unsigned long #define __EDG_VERSION__ 411 #define __ELF__ 1 #define __FINITE_MATH_ONLY__ 0 #define __FLOAT_WORD_ORDER__ __ORDER_LITTLE_ENDIAN__ #define __FLT_DECIMAL_DIG__ 9 #define __FLT_DENORM_MIN__ 1.40129846e-45F #define __FLT_DIG__ 6 #define __FLT_EPSILON__ 1.19209290e-7F #define __FLT_HAS_DENORM__ 1 #define __FLT_HAS_INFINITY__ 1 #define __FLT_HAS_QUIET_NAN__ 1 #define __FLT_MANT_DIG__ 24 #define __FLT_MAX_10_EXP__ 38 #define __FLT_MAX__ 3.40282347e+38F #define __FLT_MAX_EXP__ 128 #define __FLT_MIN_10_EXP__ -37 #define __FLT_MIN__ 1.17549435e-38F #define __FLT_MIN_EXP__ -125 #define __FLT_RADIX__ 2 #define __FMA__ 1 #define __GCC_ATOMIC_BOOL_LOCK_FREE 2 #define __GCC_ATOMIC_CHAR16_T_LOCK_FREE 2 #define __GCC_ATOMIC_CHAR32_T_LOCK_FREE 2 #define __GCC_ATOMIC_CHAR_LOCK_FREE 2 #define __GCC_ATOMIC_INT_LOCK_FREE 2 #define __GCC_ATOMIC_LLONG_LOCK_FREE 2 #define __GCC_ATOMIC_LONG_LOCK_FREE 2 #define __GCC_ATOMIC_POINTER_LOCK_FREE 2 #define __GCC_ATOMIC_SHORT_LOCK_FREE 2 #define __GCC_ATOMIC_TEST_AND_SET_TRUEVAL 1 #define __GCC_ATOMIC_WCHAR_T_LOCK_FREE 2 #define __GCC_HAVE_SYNC_COMPARE_AND_SWAP_1 1 #define __GCC_HAVE_SYNC_COMPARE_AND_SWAP_2 1 #define __GCC_HAVE_SYNC_COMPARE_AND_SWAP_4 1 #define __GCC_HAVE_SYNC_COMPARE_AND_SWAP_8 1 #define _GLIBCXX_NO_BUILTIN_HAS_UNIQ_OBJ_REP 1 #define _GLIBCXX_NO_BUILTIN_LAUNDER 1 #define __GNUC__ 7 #define __GNUC_GNU_INLINE__ 1 #define __GNUC_MINOR__ 0 #define __GNUC_PATCHLEVEL__ 0 #define __GNUC_STDC_INLINE__ 1 #define __gnu_linux__ 1 #define __GXX_ABI_VERSION 1010 #define __ICC 1700 #define __INT16_MAX__ 32767 #define __INT16_TYPE__ short #define __INT32_MAX__ 2147483647 #define __INT32_TYPE__ int #define __INT64_MAX__ 9223372036854775807L #define __INT64_TYPE__ long #define __INT8_MAX__ 127 #define __INT8_TYPE__ signed char #define __INTEL_COMPILER 1700 #define __INTEL_COMPILER_BUILD_DATE 20170411 #define __INTEL_COMPILER_UPDATE 4 #define __INTEL_OFFLOAD 1 #define __INTEL_RTTI__ 1 #define __INT_FAST16_MAX__ 9223372036854775807L #define __INT_FAST16_TYPE__ long #define __INT_FAST32_MAX__ 9223372036854775807L #define __INT_FAST32_TYPE__ long #define __INT_FAST64_MAX__ 9223372036854775807L #define __INT_FAST64_TYPE__ long #define __INT_FAST8_MAX__ 127 #define __INT_FAST8_TYPE__ char #define __INT_LEAST16_MAX__ 32767 #define __INT_LEAST16_TYPE__ short #define __INT_LEAST32_MAX__ 2147483647 #define __INT_LEAST32_TYPE__ int #define __INT_LEAST64_MAX__ 9223372036854775807L #define __INT_LEAST64_TYPE__ long #define __INT_LEAST8_MAX__ 127 #define __INT_LEAST8_TYPE__ char #define __INT_MAX__ 2147483647 #define __INTMAX_MAX__ 0x7fffffffffffffff #define __INTMAX_TYPE__ long int #define __INTPTR_MAX__ 9223372036854775807L #define __INTPTR_TYPE__ long #define __LDBL_DENORM_MIN__ 3.64519953188247460253e-4951L #define __LDBL_DIG__ 18 #define __LDBL_EPSILON__ 1.08420217248550443401e-19L #define __LDBL_HAS_DENORM__ 1 #define __LDBL_HAS_INFINITY__ 1 #define __LDBL_HAS_QUIET_NAN__ 1 #define __LDBL_MANT_DIG__ 64 #define __LDBL_MAX_10_EXP__ 4932 #define __LDBL_MAX__ 1.18973149535723176502e+4932L #define __LDBL_MAX_EXP__ 16384 #define __LDBL_MIN_10_EXP__ -4931 #define __LDBL_MIN__ 3.36210314311209350626e-4932L #define __LDBL_MIN_EXP__ -16381 #define __linux 1 #define __linux__ 1 #define linux 1 #define __LONG_DOUBLE_SIZE__ 80 #define __LONG_LONG_MAX__ 0x7fffffffffffffff #define __LONG_MAX__ 9223372036854775807L #define __LP64__ 1 #define _LP64 1 #define __MMX__ 1 #define __NO_MATH_INLINES 1 #define __NO_STRING_INLINES 1 #define __OPTIMIZE__ 1 #define __ORDER_BIG_ENDIAN__ 4321 #define __ORDER_LITTLE_ENDIAN__ 1234 #define __ORDER_PDP_ENDIAN__ 3412 #define __pentium4 1 #define __pentium4__ 1 #define __PRAGMA_REDEFINE_EXTNAME 1 #define __PTRDIFF_MAX__ 9223372036854775807L #define __PTRDIFF_TYPE__ long #define __QMSPP_ 1 #define __REGISTER_PREFIX__ #define __SCHAR_MAX__ 127 #define __SHRT_MAX__ 32767 #define __SIG_ATOMIC_MAX__ 2147483647 #define __SIG_ATOMIC_MIN__ (-__SIG_ATOMIC_MAX__ - 1) #define __SIG_ATOMIC_TYPE__ int #define __SIGNED_CHARS__ 1 #define __SIZE_MAX__ 18446744073709551615UL #define __SIZEOF_DOUBLE__ 8 #define __SIZEOF_FLOAT__ 4 #define __SIZEOF_INT128__ 16 #define __SIZEOF_INT__ 4 #define __SIZEOF_LONG__ 8 #define __SIZEOF_LONG_DOUBLE__ 16 #define __SIZEOF_LONG_LONG__ 8 #define __SIZEOF_POINTER__ 8 #define __SIZEOF_PTRDIFF_T__ 8 #define __SIZEOF_SHORT__ 2 #define __SIZEOF_SIZE_T__ 8 #define __SIZEOF_WCHAR_T__ 4 #define __SIZEOF_WINT_T__ 4 #define __SIZE_TYPE__ unsigned long #define __SSE__ 1 #define __SSE2__ 1 #define __SSE2_MATH__ 1 #define __SSE3__ 1 #define __SSE4_1__ 1 #define __SSE4_2__ 1 #define __SSE_MATH__ 1 #define __SSSE3__ 1 #define __STDC__ 1 #define __STDC_DEC_FP__ 200704L #define __STDC_HOSTED__ 1 #define __STDC_NO_ATOMICS__ 1 #define __STDC_UTF_16__ 1 #define __STDC_UTF_32__ 1 #define __STDC_VERSION__ 201112L #define __TIME__ "09:48:47" #define __tune_pentium4__ 1 #define __UINT16_MAX__ 65535 #define __UINT16_TYPE__ unsigned short #define __UINT32_MAX__ 4294967295U #define __UINT32_TYPE__ unsigned int #define __UINT64_MAX__ 18446744073709551615UL #define __UINT64_TYPE__ unsigned long #define __UINT8_MAX__ 255 #define __UINT8_TYPE__ unsigned char #define __UINT_FAST16_MAX__ 18446744073709551615UL #define __UINT_FAST16_TYPE__ unsigned long #define __UINT_FAST32_MAX__ 18446744073709551615UL #define __UINT_FAST32_TYPE__ unsigned long #define __UINT_FAST64_MAX__ 18446744073709551615UL #define __UINT_FAST64_TYPE__ unsigned long #define __UINT_FAST8_MAX__ 255 #define __UINT_FAST8_TYPE__ unsigned char #define __UINT_LEAST16_MAX__ 65535 #define __UINT_LEAST16_TYPE__ unsigned short #define __UINT_LEAST32_MAX__ 4294967295U #define __UINT_LEAST32_TYPE__ unsigned int #define __UINT_LEAST64_MAX__ 18446744073709551615UL #define __UINT_LEAST64_TYPE__ unsigned long #define __UINT_LEAST8_MAX__ 255 #define __UINT_LEAST8_TYPE__ unsigned char #define __UINTMAX_MAX__ 0xffffffffffffffff #define __UINTMAX_TYPE__ long unsigned int #define __UINTPTR_MAX__ 18446744073709551615UL #define __UINTPTR_TYPE__ unsigned long #define __unix 1 #define __unix__ 1 #define unix 1 #define __USER_LABEL_PREFIX__ #define __VERSION__ "Intel(R) C++ gcc 7.0 mode" #define __WCHAR_MAX__ 2147483647 #define __WCHAR_MIN__ (-__WCHAR_MAX__ - 1) #define __WCHAR_TYPE__ int #define __WINT_MAX__ 4294967295U #define __WINT_MIN__ 0U #define __WINT_TYPE__ unsigned int #define __x86_64 1 #define __x86_64__ 1 skylake:$
- Tags:
- CC++
- Development Tools
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
In the gcc compiler, you may need to add the "-madx" option which also enables the __ADX__ target specific macro. But that's not necessary on the Intel compiler and icc doesn't activate the target macro's in the same way that gcc does.
gcc -c -madx -dM -E test.c | grep ADX
#define __ADX__ 1
icc -c -madx -dM -E test.c | grep ADX
icc: command line warning #10159: invalid argument for option '-m'
See, without the -madx argument, gcc doesn't create the macro:
gcc -c -dM -E test.c | grep ADX
I wrote a small test case to confirm that the adx instructions are being generated
icc -c -S test.c
grep adcx test.s
adcx %rdx, %rsi #5.9
cat test.c
unsigned char fu(
unsigned char c_in, unsigned __int64 a, unsigned __int64 b, unsigned __int64 * out)
return _addcarryx_u64 (c_in, a, b, out);
Can you use intrinsics? _addcarryx_u32/addcarryx_u64
Viet Hoang
#define __ADX__ 1
icc -c -S test.c
grep adcx test.s
cat test.c
unsigned char fu(
Thanks Viet Hoang and Melanie Blower. Please forgive my ignorance...
When using ICC, how do we know when a user wants a particular target feature? In the case of ADX, is it lumped into AVX2 (such that __AVX2__ signals it)?
If not, what happens when I want to build for a minimum target like AVX? How do I know _not_ to enable AVX2 and BMI2, and ADX in this case?
And I guess the other question is, why doesn't ICC define __ADX__ when in GCC mode? Its claiming to be GCC with __GNUC__ and friends.
I've created CMPLRS-6758 in our internal bugs database to request for the compiler to recognize -madx, and add the target macro too. Thanks for pointing this out.
The compiler does accept many of gcc's -m options and the target macro symbols defined vary depending on that option, for example I saw these differences,
using icc -c
< -D__i686__
< -D__pentiumpro
using -c -mavx
> -D__SSE3__
> -D__SSSE3__
> -D__SSE4_1__
> -D__SSE4_2__
> -D__AVX__
I think if you actually have a call to a builtin intrinsic, the compiler doesn't check if it's supported (w.r.t. the -m option that you chose) it just assumes you know what you're doing.
