I'm trying to compile Chombo on Mac OS X using the Intel compiler, however mcpcom fails after ~10 seconds, giving only the following error message
": internal error: 010101_1
This occurs whenever I try to compile at -O2 or above, but the problem disappears at -O1. Obviously this message is not very helpful to me at all as I have no idea what exactly is causing this.
The fully-preprocessed source file can be found here.
The exact compiler version is:
icpc version 15.0.1 (gcc version 4.9.0 compatibility)
The version of the LLVM/Clang toolchain used to setup the environment is:
Apple LLVM version 6.0 (clang-600.0.56) (based on LLVM 3.5svn)
Target: x86_64-apple-darwin14.0.0
Thread model: posix
In case it helps, I also tried to compile the same file on Linux. The problem does NOT occur there. The compiler version on the Linux machine is:
icpc version 15.0.1 (gcc version 4.3.0 compatibility)
The gcc toolchain is:
Using built-in specs.
Target: x86_64-suse-linux
Configured with: ../configure --prefix=/usr --infodir=/usr/share/info --mandir=/usr/share/man --libdir=/usr/lib64 --libexecdir=/usr/lib64 --enable-languages=c,c++,objc,fortran,obj-c++,java,ada --enable-checking=release --with-gxx-include-dir=/usr/include/c++/4.3 --enable-ssp --disable-libssp --with-bugurl=http://bugs.opensuse.org/ --with-pkgversion='SUSE Linux' --disable-libgcj --disable-libmudflap --with-slibdir=/lib64 --with-system-zlib --enable-__cxa_atexit --enable-libstdcxx-allocator=new --disable-libstdcxx-pch --enable-version-specific-runtime-libs --program-suffix=-4.3 --enable-linux-futex --without-system-libunwind --with-cpu=generic --build=x86_64-suse-linux
Thread model: posix
gcc version 4.3.4 [gcc-4_3-branch revision 152973] (SUSE Linux)
The fully-preprocessed source file from the Linux machine can be found here.
>>>Obviously this message is not very helpful to me >>>
Because this is ICE and this kind of error description is probably not intended to be meaningful for compiler user.
Yes, however I thought someone from Intel might be able to provide extra info on exactly which line of code triggered this. I suspect this might be something in Clang's C++ library as I also managed to trigger the same error with a few other source files from Chombo.
I don't have access to Premier Support, so here is just about my only point of contact with Intel.
Hi Saran,
Thank you for the preprocessed source file. I reproduced the problem with it, and entered this issue to our problem-tracking database.
Hi Saran,
I was informed that this issue has been addessed in Composer XE 2015 Update 3, which could be downloaded in https://registrationcenter.intel.com. I’m closing this issue now. Please feel free to reopen it or create a new issue if the problem still persists in Update 3.
Thank you for your issue submission.
