When building a project with Intel C++ I am getting a warning on a particular file:
icl: warning #10210: problem with Microsoft compilation of '..\source\DspFilter.cpp'
This results in a build error:
BSCMAKE: error BK1506 : cannot open file 'C:\Dev\_build\_int\DSPTestRelDebug\DspFilter.sbr': No such file or directory
When I change the compiler used just for that one source file, to Microsoft Visual C++, no errors or warnings are generated.
The resulting .exe is still produced in either case; However the error prevents dependent targets from getting built.
Quoting - thevinn
icl: warning #10210: problem with Microsoft compilation of '..sourceDspFilter.cpp'
BSCMAKE: error BK1506 : cannot open file 'C:Dev_build_intDSPTestRelDebugDspFilter.sbr': No such file or directory
Jennifer
Where does the build log go?
Quoting - thevinn
The buildlog.htm can be found under the "Debug" or "Release" directory.
Jennifer
I have attached two logs, one the result of the Intel C++ compiler and the other with the result of the Microsoft Visual C++ compiler. Here is my scenario:
My project is a static library, the target is RelDebug. It is configured to use Intel C++ for all files.
For the Microsoft Visual C++ log, I changed the one source file having problems (DspFilter.cpp) to use the Microsoft compiler, without changing anything else, and performed a rebuild.
Thanks for the log files. That helps.
There's a bug in the compiler driver in interpreting the option /FR"c:hellodebug". the icl generates debug.sbr.
Also when trying duplicating this issue, I found an IDE integration bug when setting the /FR field value to something else, the generatedcmd "bscmake.exe" has bad parameters.
For work-around, set this file "DspFilter.cpp" 's property field"Browser file" as "inherite from project". It should work after.
Jennifer
Jennifer
Quoting - Jennifer Jiang (Intel)
Can you also upload the .vcproj file please? Or upload file "DspFilter.cpp" property page: "Browser Information".
My error msg is different than yours. But I'd think the work-around should be the same.
Thanks again,
Jennifer
DspFilter is an open source library I wrote, if you want to try to compile it, here is is:
http://code.google.com/p/dspfilterscpp/downloads/list
It is just one .cpp and .h
Attached is the .vcproj with DspFilter.cpp (and other sources).
Thanks thevinn.
I'll try your program with our compiler for all the issues you've reported today.
Jennifer
DspFilter.cpp was the only source file in the project has "Use Precompiled Headers" set to "No". When I changed DspFilter.cpp to the same setting as all the other files, and add the necessary #include for the precompiled header (my project uses precompiled headers) this problem goes away.
UPDATE: Nope, its back...
Quoting - thevinn
Hallo Jennifer,
I had have the same probs with icl: warning #10210: and BSCMAKE: error BK1506 using "Parallel Studio"
I switched off the /FRoption and the project compilessuccessful.
thanks
the issue with BSCMAKE error is fixed in the 12.0 Intel Parallel Composer 2011 and Intel C++ Composer XE.
thanks,
Jennifer
It seems similar issues sometimes happens in Intel Compiler 2018 Update 1.
