Intel® C++ Compiler
Support and discussions for creating C++ code that runs on platforms based on Intel® processors.
7690 Discussions
"typedef double v4df __attribute__((vector_size(32)));" with OpenMP makes strange output.
Hiroyuki_Yata
Please decompress the attached file and do "make, make test", then you will find the following.
"icpc & -DV4DF=auto",  "g++ & -DV4DF=auto", "g++ & -DV4DF=v4df" make right output.
On the other hand, "icpc & -DV4DF=v4df" make wrong output.
Thank you
Judith_W_Intel
First, what version of the Intel compiler and what version of GNU are you using? What operating system and architecture?
I see the same result with both icpc_vfdf.out and icpc_auto.out, i.e.:
sptel15-208> icpc_v4df.out
A pair-file is found. I use it.
Number of pairs: 15679772
Illegal instruction (core dumped)
sptel15-209> icpc_auto.out
sptel15-210>
I also can't get gcc 5.4.0 to compile the test case:
g++ -O3 -march=native -std=c++11 -fopenmp -DV4DF=v4df test.cpp -o gcc_v4df.out
In file included from /site/spt/rdrive/ref/gcc/5.4.0/rhel60/efi2/lib/gcc/x86_64-linux-gnu/5.4.0/include/immintrin.h:43:0,
                 from test.cpp:2:
/site/spt/rdrive/ref/gcc/5.4.0/rhel60/efi2/lib/gcc/x86_64-linux-gnu/5.4.0/include/avx2intrin.h: In function ‘<built-in>’:
/site/spt/rdrive/ref/gcc/5.4.0/rhel60/efi2/lib/gcc/x86_64-linux-gnu/5.4.0/include/avx2intrin.h:1049:1: error: inlining failed in call to always_inline ‘__m          256d _mm256_permute4x64_pd(__m256d, int)’: target specific option mismatch
 _mm256_permute4x64_pd (__m256d __X, const int __M)
test.cpp:187:52: error: called from here
         V4DF vdf_d = _mm256_permute4x64_pd(vdf, 255);
                 from test.cpp:2:
test.cpp:186:52: error: called from here
         V4DF vdf_c = _mm256_permute4x64_pd(vdf, 170);
thanks
Judy
