Intel® C++ Compiler
7956 Discussions
"warning #711: ellipsis with no explicit parameters is nonstandard" with "-strict-ansi"
Yakov_Mindelis
With upgrade to icc18.0.1 the following warning appears when "-strict-ansi" argument is supplied:
icc18_toupper_test.c(6): warning #711: ellipsis with no explicit parameters is nonstandard
  	v = toupper(v);
With icc15 this message did not appear.
Compiler  is installed x86_64 Linux.
The code is attached, compilation cmd:
icc -strict-ansi icc18_toupper_test.c
How do I get rid of this warning?
Viet_H_Intel
You can add -wd711 to your command line to turn off this warning.
Viet
Yakov_Mindelis
Hi Viet,
Is there any specific reason that causes this warning? I prefer not disabling warnings for all variadic functions.
nemequ
With glibc, your code gets preprocessed to something like
int main(void)
    unsigned char v = 'a';
    v = (__extension__({
        int __res;
        if (sizeof(v) > 1)
            if (__builtin_constant_p(v))
                int __c = (v);
                __res = __c < -128 || __c > 255 ? __c
                                                : (*__ctype_toupper_loc())[__c];
            } else
                __res = toupper(v);
        } else
            __res = (*__ctype_toupper_loc())[(int)(v)];
        __res;
    return (0);
If we run it through the compiler (with -strict-ansi), the warning gets triggered on the __builtin_constant_p call. __builtin_constant_p is type-generic, so I guess the compiler implements it internally just like a variadic function. The problem can be triggered a bit more simply (and without depending on glibc) with:
int main(void) {
  return __builtin_constant_p('a');
