I am trying to use the Intel compiler with visual studio 2019, but I always get the error:
error MSB6006: "xilink.exe" exited with code -1073741819.
I have found similar issues on the forum, but neither provided a solution for me. The same error occurs with VS2017, VS2019, and VS2019 preview. My VS2019 version is 16.6.5, while the Intel compiler version is 19.1. You can find the build log attached.
I have since uninstalled the Intel compiler, and all of my msvc versions, and I have reinstalled vs2019 and the Intel compiler. This did not fix the issue.
Could you try creating a new C++ project with Intel C++ compiler and build/run a sample code (just print something) and see if it works?
Try it out with both debug and release modes.
Also, kindly upgrade your parallel studio to the latest release if not done already.
Let me know if it helps.
--Rahul
I created a project with just int main() { return 0; } and got the exact same error. I tried it in both debug, release, x86, x64. As mentioned, I already reinstalled everything so I have the latest version of both vs2019 and parallel studio. Something noteworthy is that `icl` was not set in the environment path, so I had to go to "C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2020.2.254\windows\bin" and run "compilervars.bat intel64". Now I can compile code just fine from the command line, but I get the exact same error as before in vs2019.
can you run this from the command line to see if you still reproduce the xilink.exe error?
C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\MSBuild\Current\Bin\Tracker.exe /a /d "C:\Program Files (x86)\MSBuild\15.0\FileTracker\FileTracker32.dll" /i "D:\Vasko\work\Weickert\Weickert code\ref_code_collection\demonstrator_linear_splines\build\demonstrator_linear_splines\x64\Release\demonstr.a0cbfe50.tlog" /r "D:\VASKO\WORK\WEICKERT\WEICKERT CODE\REF_CODE_COLLECTION\DEMONSTRATOR_LINEAR_SPLINES\BUILD\DEMONSTRATOR_LINEAR_SPLINES\X64\RELEASE\DEMONSTRATOR_LINEAR_SPLINES.OBJ" /b MSBuildConsole_CancelEvent8420387b9ec44b729e9e063e5a4a595d /c "D:\Vasko\Programs\Intel Parallel Studio XE\compilers_and_libraries_2020\windows\bin\Intel64\xilink.exe" -qm64 /OUT:"D:\Vasko\work\Weickert\Weickert code\ref_code_collection\demonstrator_linear_splines\build\demonstrator_linear_splines\x64\Release\demonstrator_linear_splines.exe" /INCREMENTAL:NO /NOLOGO /LIBPATH:"D:\Vasko\Programming2\vcpkg\installed\x64-windows\lib" /LIBPATH:"D:\Vasko\Programming2\vcpkg\installed\x64-windows\lib\manual-link" kernel32.lib user32.lib gdi32.lib winspool.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib odbc32.lib odbccp32.lib "D:\Vasko\Programming2\vcpkg\installed\x64-windows\lib\*.lib" /MANIFEST /manifest:embed /MANIFESTUAC:"level='asInvoker' uiAccess='false'" /DEBUG /PDB:"D:\Vasko\work\Weickert\Weickert code\ref_code_collection\demonstrator_linear_splines\build\demonstrator_linear_splines\x64\Release\demonstrator_linear_splines.pdb" /SUBSYSTEM:CONSOLE /OPT:REF /OPT:ICF /TLBID:1 /DYNAMICBASE /NXCOMPAT /IMPLIB:"D:\Vasko\work\Weickert\Weickert code\ref_code_collection\demonstrator_linear_splines\build\demonstrator_linear_splines\x64\Release\demonstrator_linear_splines.lib" /MACHINE:X64 x64\Release\demonstrator_linear_splines.obj
The above won't work since I have deleted the project since. I made a new project (which I will keep this time around), the log is attached below.
Can you try this from the command:
C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2020\windows\bin\Intel64\xilink.exe -qm64 /OUT:"D:\Vasko\work\intel_compiler\comp\x64\Release\comp.exe" /INCREMENTAL:NO /NOLOGO /LIBPATH:"D:\Vasko\Programming2\vcpkg\installed\x64-windows\lib" /LIBPATH:"D:\Vasko\Programming2\vcpkg\installed\x64-windows\lib\manual-link" kernel32.lib user32.lib gdi32.lib winspool.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib odbc32.lib odbccp32.lib "D:\Vasko\Programming2\vcpkg\installed\x64-windows\lib\*.lib" /MANIFEST /manifest:embed /MANIFESTUAC:"level='asInvoker' uiAccess='false'" /DEBUG /PDB:"D:\Vasko\work\intel_compiler\comp\x64\Release\comp.pdb" /SUBSYSTEM:CONSOLE /OPT:REF /OPT:ICF /TLBID:1 /DYNAMICBASE /NXCOMPAT /IMPLIB:"D:\Vasko\work\intel_compiler\comp\x64\Release\comp.lib" /MACHINE:X64 x64\Release\main.obj
Then also run:
C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\MSBuild\Current\Bin\Tracker.exe /a /d "C:\Program Files (x86)\MSBuild\15.0\FileTracker\FileTracker32.dll" /i D:\Vasko\work\intel_compiler\comp\x64\Release\comp.tlog /r D:\VASKO\WORK\INTEL_COMPILER\COMP\X64\RELEASE\MAIN.OBJ /b MSBuildConsole_CancelEvent30fdf23028884619ba1e73b9c04a6b12 /c "C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2020\windows\bin\Intel64\xilink.exe" -qm64 /OUT:"D:\Vasko\work\intel_compiler\comp\x64\Release\comp.exe" /INCREMENTAL:NO /NOLOGO /LIBPATH:"D:\Vasko\Programming2\vcpkg\installed\x64-windows\lib" /LIBPATH:"D:\Vasko\Programming2\vcpkg\installed\x64-windows\lib\manual-link" kernel32.lib user32.lib gdi32.lib winspool.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib odbc32.lib odbccp32.lib "D:\Vasko\Programming2\vcpkg\installed\x64-windows\lib\*.lib" /MANIFEST /manifest:embed /MANIFESTUAC:"level='asInvoker' uiAccess='false'" /DEBUG /PDB:"D:\Vasko\work\intel_compiler\comp\x64\Release\comp.pdb" /SUBSYSTEM:CONSOLE /OPT:REF /OPT:ICF /TLBID:1 /DYNAMICBASE /NXCOMPAT /IMPLIB:"D:\Vasko\work\intel_compiler\comp\x64\Release\comp.lib" /MACHINE:X64 x64\Release\main.obj
I wanted to see if the error came directly from "xilink.exe" or from executed "Tracker.exe"
I got the following error after running the second part:
TRACKER : error TRK0006: Failed to open cancel event "MSBuildConsole_CancelEvent30fdf23028884619ba1e73b9c04a6b12". The system cannot find the file specified.
Seems like that file had been deleted.
Will you able to run this?
C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\MSBuild\Current\Bin\Tracker.exe /a /d "C:\Program Files (x86)\MSBuild\15.0\FileTracker\FileTracker32.dll" /i D:\Vasko\work\intel_compiler\comp\x64\Release\comp.tlog /r D:\VASKO\WORK\INTEL_COMPILER\COMP\X64\RELEASE\MAIN.OBJ /c "C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2020\windows\bin\Intel64\xilink.exe" -qm64 /OUT:"D:\Vasko\work\intel_compiler\comp\x64\Release\comp.exe" /INCREMENTAL:NO /NOLOGO /LIBPATH:"D:\Vasko\Programming2\vcpkg\installed\x64-windows\lib" /LIBPATH:"D:\Vasko\Programming2\vcpkg\installed\x64-windows\lib\manual-link" kernel32.lib user32.lib gdi32.lib winspool.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib odbc32.lib odbccp32.lib "D:\Vasko\Programming2\vcpkg\installed\x64-windows\lib\*.lib" /MANIFEST /manifest:embed /MANIFESTUAC:"level='asInvoker' uiAccess='false'" /DEBUG /PDB:"D:\Vasko\work\intel_compiler\comp\x64\Release\comp.pdb" /SUBSYSTEM:CONSOLE /OPT:REF /OPT:ICF /TLBID:1 /DYNAMICBASE /NXCOMPAT /IMPLIB:"D:\Vasko\work\intel_compiler\comp\x64\Release\comp.lib" /MACHINE:X64 x64\Release\main.obj
I was able to run the above just fine, without any errors.
Seems like it works from the command line.
The VS2019 version you use is pretty new (released on Jul/21/2020) and Intel compiler 2020 update 2 ( built date Jul/1/2020). Is there a way you can try on VS2019 versions which released before the compiler built date (e.g. VS2019 version16.6.1) to see if the problem still occurs?
It is not recommended to use the VS versions that released after the compiler built date because we didn't have a way to validate that VS versions prior to releasing the compiler.
Can you let us know which specific older VS versions you have tried and saw the same issue so that I can escalate it to the integration team?
I tested on VS2019 version 16.5.5. It worked fine.
This issue has been resolved and we will no longer respond to this thread.
If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
