Intel® C++ Compiler
7833 Discussions
regression: no operator "=" matches these operands for std::tie = std::tuple
Matthias_Kretz
Testcase:
[cpp]
#include <tuple>
std::tuple<int, int, int> f();
void g() {
    int a, b, c;
    std::tie(a, b, c) = f();
[/cpp]
Compile with:
[plain]
/opt/intel/composer_xe_2013_sp1.0.080/bin/intel64/icpc -mmic -std=c++11 -c -o tie.o tie.cpp
tie.cpp(7): error: no operator "=" matches these operands
            operand types are: std::tuple<int &, int &, int &> = std::tuple<int, int, int>
compilation aborted for tie.cpp (code 2)
[/plain]
It was fine with ICC 13:
[plain]/opt/intel/composer_xe_2013.5.192/bin/intel64/icpc -mmic -std=c++11 -c -o tie.o tie.cpp[/plain]
Casey
That testcase compiles fine for me with icpc 14.0.0 20130728 on Linux without "-mmic" (I don't have the MIC environment and couldn't test that). Does it build without MIC for you?  Perhaps the regression is in that environment.
Matthias_Kretz
Yes, I tested it without -mmic and yes, it only fails for -mmic.
JenniferJ
yeh. looks like a bug to me. I'll file a bug report to the compiler team.
thanks for reporting.
Jennifer
JenniferJ
FYI.
This bug has been fixed in 14.0 update 2 or later, the 15.0.
Jennifer
