Will someone please educate me on this remark from the C compiler? In particular:
1) what is it trying to tell me?
2) is it something I should worry about in terms of the integrity of my code?
3) what do I need to do to address it so that I don't get reams of "remarks" when I compiler (I like a nice clean output with no errors, warning, messages, remarks, etc... ;^))
The following shows some code to generate the remark. It's pared down from a larger code that needs to process a 32bit aligned array that is stored byte swapped (don't blame me, I didn't write that part). This code is useless, but you'll get the idea. (It's also all retyped so hopefully I didn't make any typos).
> cat x.c #include <immintrin.h> #define BSWAP32(x) _bswap(x) #define BSWAP128(x) _mm_shuffle_epi8((x), _mm_set_epi32(0x0C0D0E0F, 0x08090A0B, 0x04050607, 0x00010203)) #define 10 int main(int argc, char *argv[]) { unsigned int x[4*N]; unsigned int y[4*N]; for (int i=0; i<N; i++) { __m128i z = BSWAP128(_mm_lddqu_si128((const __m128i *)&x[i*4])); // werk, werk, werk... _mm_storeu_si128((__m128i *)&y[i*4], BSWAP(z)); } for (int i=0; i<N; i++) { __m128i z = _mm_set_epi32(BSWAP32(x[4*i+3]),BSWAP32(x[4*i+2]),BSWAP32(x[4*i+1]),BSWAP32(x[4*i+0])); // werk, werk, werk... _mm_storeu_si128((__m128i *)&y[i*4], BSWAP(z)); } for (int i=0; i<N; i++) { __m128i xx = _mm_lddqu_si128((const __m128i *)&x[i*4]); __m128i z = BSWAP128(xx); // werk, werk, werk... _mm_storeu_si128((__m128i *)&y[i*4], BSWAP(z)); } } > icc --version ic (ICC) 15.0.0 20140723 Copyright (C) 1985-2014 Intel Corporation. All rights reserved. > icc -std=c99 -xHost -O3 -w3 x.c icc: command line remark #10382: option '-xHOST' setting '-xCORE-AVX2' x.c(16): remark #981: operands are evaluated in unspecified order __m128i z = BSWAP128(_mm_lddqu_si128((const __m128i *)&x[i*4])); ^ x.c(16): remark #981: operands are evaluated in unspecified order __m128i z = BSWAP128(_mm_lddqu_si128((const __m128i *)&x[i*4])); ^ x.c(21): remark #981: operands are evaluated in unspecified order __m128i z = _mm_set_epi32(BSWAP32(x[4*i+3]),BSWAP32(x[4*i+2]),BSWAP32(x[4*i+1]),BSWAP32(x[4*i+0])); ^ x.c(21): remark #981: operands are evaluated in unspecified order __m128i z = _mm_set_epi32(BSWAP32(x[4*i+3]),BSWAP32(x[4*i+2]),BSWAP32(x[4*i+1]),BSWAP32(x[4*i+0])); ^
Anyway, this is something I've never seen before (and only showed up with -w3) so I'd like to understand it better.
You must be enabling remarks (this remark is not emitted by default):
Here's some helpful posts on this remark:
https://software.intel.com/en-us/forums/intel-c-compiler/topic/287491
https://software.intel.com/en-us/forums/intel-c-compiler/topic/299290
If these don't answer your questions please let us know.
Sounds like the message should be something more like "remark #981: Wolf!" ;^).
#pragma warning (disable:981) looks like my best option.
