Intel® C++ Compiler
rpath > 4096 chars causes segmentation fault
Kelly_T_1
I'm trying to compile trilinos from a deep directory heirarchy and I ran into an issue where icpc generates a segmentation fault if the argument to -rpath is longer than 4096 characters.  This occurs with 15.0.5 and 16.0.3 for Linux. This problem can be reproduced with a toycode:
// hw.cc
#include <iostream>
int main() { std::cout << "Hello, world!" << std::endl; return 0; }
and a compile line like this
$ icpc hw.cc -Wl,-rpath,/path1:/path2:/...[4096 chars]
Segmentation fault (core dumped)
In my case the paths given to rpath are about 90 characters each and there are about 55 entries (~5000 chars). Shortening the rpath string to < 4096 eliminates the error.
This seems like a bug. I think this artificial limitation should be increased or eliminated.
TimP
Such limitation isn't under the control of Intel developers, as it pertains to the underlying tools provided by your platform.  Likewise, work-around would be the same as for gcc et al.
Kelly_T_1
Tim - Thank's for you input.  I'll work with my sysadmin on this issue.
Judith_W_Intel
I can't reproduce this on the system I am using. Like Tim suggested it could be a limitation of the "ld" on your system. Do you see the same problem is you say "ld -rpath /reallylongfilename hw.o"? If so the problem is the linker not the compiler.
Judith_W_Intel
Does your path name have a period in it?
We just got in a bug report with this description:
Compile any file:
$ icc -Wl,-rpath=.01234567891123456789212345678931234567894123456789512345678961234567897 hello.c
icc: internal error: Assertion failed (shared/driver/drvutils.c, line 209)
The combination of initial period and very long directory name causes the error.
Analysis:
The failure is occurring due to a check for an possible filename extension, and not expecting an extension of such great length.  The only options are what you requested and possibly a slight change to the directory.
•         Shorten the name
•         remove the '.'
•         add a '.' towards the end (.<long string>.<short string>)
Kelly_T_1
Judith,
My test case has several periods in the middle of a ~140 character path.  For example:
-Wl,-rpath,/usr/projects/draco/vendors/spack.ml.20160803/opt/spack/linux-redhat6-x86_64/intel-16.0.3/boost-1.61.0-bxys3tl5ggpnmrpts5z6inlrzeowo63e/lib:[plus ~40 more similar paths]
I've worked around the problem through the extensive use of symbolic links (not pretty, but it works).
-kt
Judith_W_Intel
ok  -- sorry for the inconvenience...
Judy
