Intel® C++ Compiler
7830 Discussions
__sec_reduce_all_nonzero crashing compiler with backend signals
MHlav
Why does the following code crash the compiler with backend signals?  Am I doing something wrong?
#include <mathimf.h>
#include <float.h>
double avec[] = {0, 1, 2, 3, 4};
__sec_reduce_all_nonzero(_finite(avec[0:sizeof(avec)/sizeof(avec[0])]));
SergeyKostrov
Valued Contributor II
I'd like to follow up: - What version of Intel C++ compiler do you use? - What is __sec_reduce_all_nonzero function? I do not see it declared in mathimf.h header file.
MHlav
It documented here:  http://software.intel.com/sites/products/documentation/doclib/iss/2013/compiler/cpp-lin/GUID-6FB572F4-A455-41D1-A799-9E6C20AF2C25.htm
I'm using Composer XE 2013 Update 5 (Intel(R) C++ Compiler XE on IA-32, version 13.1.3 Package ID: w_ccompxe_2013.5.198)
Amanda_S_Intel
Thanks for the nice test case - I will pass this on to the developers. The issue ID is DPD200246880.
SergeyKostrov
>>It documented here: http://software.intel.com/sites/products/documentation/doclib/iss/2013/compiler/ >>cpp-lin/GUID-6FB572F4-A455-41D1-A799-9E6C20AF2C25.htm >> >>I'm using Composer XE 2013 Update 5 (Intel(R) C++ Compiler XE on IA-32, version 13.1.3 Package ID: >>w_ccompxe_2013.5.198) Thanks. I see that the function you're talking about is a built-in function and is Not declared in any header files.
Amanda_S_Intel
This is targeted to be fixed in an upcoming release.
Amanda_S_Intel
This problem is fixed in Intel® C++ Composer XE 2013 SP1 Update 1. Thanks for your report.
