Intel® C++ Compiler
segmentation fault
vielmaj
I am installing the Intel C++ in Ubuntu 10.0.025 and I wrote down everything I did below. When I run "icc --version" I get "Segmentation fault". I get the same if I reboot. I don't find any logs that give the error.
from synaptic need alien, possibly glibc
go to /local/Intel_Compilers
tar -zxvf l_cc_c_10.0.025.tar.gz
go to /local/Intel_Compilers/l_cc_c_10.0.025/data
alien -cv intel-icce100025-10.0.025-1.em64t.rpm #for 64 bit system
then
dpkg -i intel-icce100025_10.0.025-2_amd64.deb
copy license to
/opt/intel/cce/10.0.025/licenses
go to /opt/intel/cce/10.0.025/bin
run
perl -pi -w -e 's//\/opt\/intel\/cce\/10.0.025/g;' *
perl -pi -w -e 's/bin\/sh/bin\/bash/g;' *
. ./iccvars.sh
add the following to /etc/profile
# Intel Compilers #
. /opt/intel/cce/10.0.025/bin/iccvars.sh
Brandon_H_Intel
Quoting - vielmaj
then
copy license to
run
perl -pi -w -e 's///opt/intel/cce/10.0.025/g;' *
perl -pi -w -e 's/bin/sh/bin/bash/g;' *
. ./iccvars.sh
# Intel Compilers #
On 10.0, "icc" was a script that set up some environment variables and called "iccbin". Open that "icc" script and make sure that all the paths and everything look ok and that the call to iccbin is working - you should be able to call iccbin directly like the script does - see if that direct call seg faults. I would encourage you to try 10.1 or above as well as that was when our Release Notes first started listing Ubuntu* as a supported flavor of Linux*.
dpeterc
Quoting - vielmaj
# Intel Compilers #
Could it be a typo in your profile where you should omit the initial dot?
and have just
I use later versions of icc, combined by bash shell, so my .bashrc contains
source /opt/intel/Compiler/11.1/046/bin/iccvars.sh ia32
TimP
icc -V
is the nearest equivalent to gcc --version
Is your segfault associated with passing unsupported options to icc?
vielmaj
I get the segmentation fault when I directly call iccbin.
