Intel® C++ Compiler
sh incompatibility in mklvars.sh
Matthias_Kretz
the mklvars.sh script shipped with the Linux edition of the Intel compiler fails to work on zsh because it is sh incompatible: The use of [ "" == "" ] is incorrect and instead [ "" = "" ] must be used.
I had to patch that script to be able to use the environment script provided by the package.
Cheers,
Matthias
JenniferJ
Thanks for letting us know.
I'll file a bug report about it.
Jennifer
barragan_villanueva_
Valued Contributor I
According to man sh
CONDITIONAL EXPRESSIONS
Conditional expressions are used by the [[ compound command and the test and [ builtin commands to test file attributes and perform
string and arithmetic comparisons.
string1 == string2
True if the strings are equal. = may be used in place of == for strict POSIX compliance.
So, '==' is OK
mecej4
Black Belt
So, '==' is OK
Yes, but not if Zsh expects POSIX compliance or does not understand Bash extensions to sh.
Looking at "info Zsh" (Conditional Expressions) (zsh 4.2.6)
STRING = PATTERN
STRING == PATTERN
true if STRING matches PATTERN. The `==' form is the preferred
one. The `=' form is for backward compatibility and should be
considered obsolete.
Therefore, Zsh must workas sh and bash
dschwen
Zsh needs the == to be escaped (\=\=), which bash accepts but not sh.
There obviously is a problem for several users here, which has an easy solution: respecting POSIX compliance.
The single = works as expected in all three shells.
