Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
short program which only works correctly when compiled in debug mode
Hi everyone,
we are using the Intel compiler v11 for Linux (11.069 and 11.074) and for Windows (11.061).
Compiling the following short program with
> icc -O0 main.cc
the executable a.out runs in an infinitely loop as expected.
Compiling this programm with
> icc -O1 main.cc
the executable a.out aborts.
This effect appears with all the Intel compilers mentioned above, but does not appear if we use gcc.
[cpp]#include
int main(void)
   int fb[1];
   int z;
   fb[0]=42;
   z=*((fb+0)+0); //  This line is essential for the effect.
                  //  If you use  z=*(fb+(0+0)) instead,
                  //  the effect vanishes.
   std::cout << "The value of fb[0] is " << fb[0] << ".n";
   std::cout << "Lets start the while loop.n" ;
   while( fb[0]==42 )
   std::cout << "Running out of the while loop.n";
}[/cpp]
Highlighted
I've filed a bug report on this, the # is "200112239".
Thanks for the posting.
Jennifer
Highlighted
I got the answer from the compiler engineer. The reason the loop gets eliminated is because there's no dependencybetween the loop and the code after. So the loop is considered dead code and is removed.
If you'd like to keep it, you should use needs to define a volatile variable & spin on it.
But the question is why using "z=*(fb+(0+0));" keeps the loop. I don't know but will find out.
Highlighted
Valued Contributor I
Jen, there may be something more to it. I tested with latest beta and changing to z = *(fb + (0 + 0)) didn't stop the compiler from optimizing it out -- on the contrary, it completely removed the code and left only the push 42 instruction before the call std::cout instruction.
Highlighted
Hello Jennifer,
in principle I understand the argumentation of the compiler engineer.
But if I write while(1) there is also no dependency between the loop and
the code after, but the loop is not considered dead code in this case and it is not
removed!
That does not sound logical to me. What is the difference (for the
compiler) between the while-loop in our program and while(1)?
Highlighted
That does not sound logical to me. What is the difference (for the compiler) between the while-loop in our program and while(1)?
Well the difference should be obvious -- 1 is a compile-time constant while (fb[0] == 42) doesn't have to be. It is a reference to a memory location which can change from the "outside". Since the compiler can determine that it doesn't change (i.e. you haven't specified it as a volatile storage), and the value is known to the compiler at compile-time the compiler eliminates the loop.
I am really not sure what to think of it though -- I would personally expect it to keep the loop as well, and optimize it out only if it said while (fb[0] != 42). I believe it is a bug.
Highlighted
The"z=..." should not affect the "while()" loop being optimized away. This is fixed in our new compiler (next release). If you'd like to keep the "while()" loop, please include a "volatile" variable local or in the loop.
Jennifer
