Intel® C++ Compiler
7956 Discussions
simple inline asm makes the compiler hanging..
Gaiger_Chen
Hi
I would like use icc to complie the sample assembly, but the compile time last almost forever
with mcpcom costing one cpu core resource 100%:
#define ASM __asm
#define ENDLINE ;
int main(void)
int a, b;
a = 10;
ASM
MOV EAX, a ENDLINE
MOV b, EAX ENDLINE
}/*ASM*/
return 0;
}/*main*/
As you watch, I replace ; as ENDLINE , that is make the compile does not complete.
when I use l instead ; , that is normal;
but the code has be compiled normally by VC 8 (VS 2005).
Is there is some restriction by #define replacing on icc ?
thank you.
My environment:
OS :windows 7 (win 6.1 ) with SP1
Intel c++ complier XE 12.0
IDE : VS 2005
cpu : intel i5 2400
board : H61 (it is cheap enough to its performance for me)
Om_S_Intel
The Intel C++ compiler behaviour ss different in this case. It seems a bug to me.
I have submitted a report to Intel C++ compiler development team. I will update this thread when I have more information on this.
Om
Om_S_Intel
The issue is fixed in latest Intel C++ Composer XE 2011. The composer is available from "Intel Regiatration and Download Center".
Om_S_Intel
levicki
Valued Contributor I
While this is a bug, it should be noted that ; is not required in __asm block as an end-of-statement marker.
Rationale:
Assembler (even inline) is not C.
