hi CP Jain,
You said you compiled the asci purple sppm benchmark
on ia32 could you provide me with the makefile of your benchmark.
and also you said you used intel compilers 8.0. also
can you attach you lam configuration options. Also
if I am not asking too much can you look for the symbol
cdwrite in the intel libraries
nm *so* > tmp
grep cdwrite tmp
Thank you,
Dev Anand
nm *so* > tmp
grep cdwrite tmp
Thank you,
Dev Anand
Hi Dev,
cdwrite is defined in the sppm benchmark itself - in c_io.c -
nm --demangle c_io.o | grep cdwrite
0000071c T cdwrite_
Also, I am using MPICH implementation of MPI and not lam impl.
I will post other details, the changes we have made in the configure script, source files etc, very soon.
CP
0000071c T cdwrite_
CP
Hi Dev,
You need to add two more macros in your Makefile -
-DREAL=double
and -DF2C=1 (This is imp - see c_io.c and you will come to know)
Also, in my Makefile, I have SYS=POSIX.
HTH,
CP
-DREAL=double
HTH,
CP
Hi Dev,
Yes, I could build irs with Intel Compiler v8 without any issue.
Is there anything specific you would like to know?
cp
cp
Okay, fine.
Let me know if you face any other issue.
CP
CP
Hi Dev,
I hope you have downloaded the silo library (available with UMT benchmark) and
compiled it with Intel compiler.
Now you have to add the include path and library path in your makefile, that's all -
SILO_LIBS = -lsilo
SILO_LIBPATH = -L/home/jain/umt2k/silo_src/silo001023/lib
SILO_INCPATH = -I/home/jain/umt2k/silo_src/silo001023/include
HTH,
cp
SILO_LIBS = -lsilo
HTH,
cp
