Below code is working good in 10.1.0.32 but failing to produce correct output
in 12.0.5
working env :: win2k8 R2 64-bti
#include
int main()
char buf[100]="ORACORE 4 6 0 1 2# none alpha";
char ver[100];
char prod[101];
int v1, v2, v3, v4, v5;
char vc=10;
char dist[102];
const char *distptr;
char reltype[5];
int rtype;
sscanf((const char *)buf, "%s%d%d%d%d%d%c%s%s", prod, &v1, &v2, &v3, &v4, &v5, &vc, dist, reltype);
printf("buf ::%s\\n",buf);
printf("sscanf ::*%s*\\n*%d*\\n*%d*\\n*%d*\\n*%d*\\n*%d*\\nvc::%d\\n*%s*\\n*%s*\\n",prod, v1, v2, v3, v4, v5, vc, dist, reltype);
thank you for letting us know and with a testcase.
I'll file the bug and get it fixed. It does not with 13.0 beta as well.
btw, the latest production compiler is 12.1 update 10. your version is a little old.
Jennifer
Jennifer
This is what I am getting:
T:\WORK>icl scan.cpp
Intel C++ Compiler XE for applications running on IA-32, Version 13.0.0.041 Beta Build 20120425
Copyright (C) 1985-2012 Intel Corporation. All rights reserved.
scan.cpp
Microsoft Incremental Linker Version 10.00.40219.01
Copyright (C) Microsoft Corporation. All rights reserved.
-out:scan.exe
scan.obj
T:\WORK>scan
buf ::
sscanf ::*ORACORE*
*4*
*6*
*0*
*1*
*2*
vc::35
*none*
*alpha*
scan.cpp
-out:scan.exe
scan.obj
T:\WORK>scan
buf ::
sscanf ::*ORACORE*
*4*
*6*
*0*
*1*
*2*
vc::35
*none*
*alpha*
Our engineer found that the following var is too small. I should have read the code more carefully as well.
If you change the "5" to "6", it works great. It is an user error in this case.
char reltype[5];
Jennifer
char reltype[5];
Jennifer
Thanks a lot.
I understood the mistake i did
As there is no space for NULL character it is placing NULL in next memory address which was already allocated to variable v1. Hence 4 is overwritten with 0.
I didn't know that all char arrays will be allocated memory consecutively on stack irrespective of the order in which they are declared in the program.
Thanks for looking into it.
Naveen
