Hi ,
I am porting and old project from Watcom C/C++ to Intel C. I have a dangerous recursive function. With Watcom I checked the free stack to predict and statck overflow using stackavail() .
Please, how can I do that with Intel C, under Windows ?
Thanks to all.
Armando
That will tell you after the error, it will not tell the program prior to error.
As Jim Dempsey said that will not avoid the stack overflow. I liked stackavail() in Watcom ...
I am testing this code:
#include "windows.h"
size_t stackavail(void)
static unsigned StackPtr; // top of stack ptr
__asm mov [StackPtr],esp // mov pointer to top of stack
static MEMORY_BASIC_INFORMATION mbi; // page range
VirtualQuery((PVOID)StackPtr,&mbi,sizeof(mbi)); // get range
return StackPtr-(unsigned)mbi.AllocationBase; // subtract from top (stack grows downward on win)
So far looks working.
Hi Serguey, My project target is Win32. It is and old implementation of a recursive fill, in memory for big bitmaps, with very complex borders. I could be over concerned because default stack size for win32 is 1 MB. In the past I got into some complex topologies that make the recursive fill stop before completion. Using stackavail() the system never crashed, it simply stoped and emited a warning. I am trying to have the same safeguard with the Intel implementation. The function stackavail() that I posted looks like to be working fine so far.
Sergey, I am afraid it is not a portable solution... It is system dependent (it works with win32 and hope with win64, not yet tested) and needs support for inlined "__asm" . Let me know about your results and considerations. Thanks
