Intel® C++ Compiler
Support and discussions for creating C++ code that runs on platforms based on Intel® processors.
status of for, each, in
William_Clements
Hi, what is the status of"for each, in" ? Is it supported?
for each (const Edge* pFindEdge in m_edges)
if (pEdge == pFindEdge)
return true;
Brandon_H_Intel
Hi William, welcome to the forum!
No, this is not working/supported currently. We have an open feature request on this that I have linked your thread to so that I can track the status of that. If there's any updates on the status of that feature request, I will let you know.
Brandon_H_Intel
Let me clarify one point, based on the code snippet you gave.
The Intel C++ Compiler does not support /clr or the managed runtimes, so "for each" syntax in that context would require an entirely different feature request. The report I referenced is in regards to "for each" syntax being applied to C++ STL containers in native compilations.
William_Clements
Agreed. I was asking about "for each" in native; i.e., STL. The source set I am working with uses "for each" a great deal.
Brandon_H_Intel
Hi William,
The Intel(R) C++ Compiler supports for,each,in syntax now with version 15.0 (available in Intel(R) Parallel Studio XE 2015, all editions). Let me know if you need anything else.
