Intel® C++ Compiler
std:: binding with c++0x std in icpc
PRASHANTH_T_
I am using icpc with -std=c++0x, in which "std::uniform_real_distribution<double> rnd" throws a couple of errors during compile time, like
WangLandau.h(103): error: qualified name is not allowed
   std::uniform_real_distribution<double> rnd;
WangLandau.h(103): error #77: this declaration has no storage class or type specifier
WangLandau.h(103): error: expected a ";"
WangLandau2d.h(92): error: qualified name is not allowed
    std::uniform_real_distribution<double> rnd; //, rnd11(-1.0,1.0),rnd0pi(0.0,2.0*M_PI);
WangLandau2d.h(92): error #77: this declaration has no storage class or type specifier
WangLandau2d.h(92): error: expected a ";"
Where am I going wrong ?
pbkenned1
icc depends on GCC headers and libraries.  What version of GCC is installed on your machine?  Your example runs correctly with g++-4.8.1.  It also runs correctly with icc-14.0.1.106 if you have that version of GCC (or later) installed.
$ g++ --version
g++ (GCC) 4.8.1
Copyright (C) 2013 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
$ icc -V
Intel(R) C Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 14.0.1.106 Build 20131008
Copyright (C) 1985-2013 Intel Corporation.  All rights reserved.
$ icc -std=c++11 U506774.cpp && ./a.out
1.12105 1.24086 1.94634 1.30563 1.01601 1.07346 1.17482 1.4248 1.39896 1.72678
patrick
JenniferJ
what is the icc version? can you post the code snippet? the gcc version?
Jennifer
PRASHANTH_T_
Version of icc is  13.1.0 20130121 , It is a random number generator
// Random number generator and distribution:
  RNG rng; std::uniform_real_distribution<double> rnd;
 do {
      x = rnd(rng); y = rnd(rng);
    } while(x*x+y*y>1);
TimP
I thought icpc 13.1 supported -std=c++11 (but not the temporary g++ option c++0x) when used with g++ 4.7 or newer, otherwise neither of those options would be supported.  I'd be reluctant to try 13.1.0; the last 13.1 or most recent 14.0 seem better bets.
PRASHANTH_T_
Same problem persists even with the icpc (ICC) 14.0.1 20131008 version.
Say for example, I want to compile this code,
#include <random>
#include <iostream>
int main()
    std::random_device rd;
    std::mt19937 gen(rd());
    std::uniform_real_distribution<> dis(1, 2);
    for (int n = 0; n < 10; ++n) {
        std::cout << dis(gen) << ' ';
    std::cout << '\n';
I am getting errors like
rand.cpp(8): error: namespace "std" has no member "uniform_real_distribution"
rand.cpp(8): error: expected an expression
rand.cpp(10): error: identifier "dis" is undefined
pbkenned1
$ g++ --version
g++ (GCC) 4.8.1
$ icc -V
patrick
PRASHANTH_T_
I get it thanks :) !
