I am using icpc with -std=c++0x, in which "std::uniform_real_distribution<double> rnd" throws a couple of errors during compile time, like
WangLandau.h(103): error: qualified name is not allowed
std::uniform_real_distribution<double> rnd;
WangLandau.h(103): error #77: this declaration has no storage class or type specifier
WangLandau.h(103): error: expected a ";"
WangLandau2d.h(92): error: qualified name is not allowed
std::uniform_real_distribution<double> rnd; //, rnd11(-1.0,1.0),rnd0pi(0.0,2.0*M_PI);
WangLandau2d.h(92): error #77: this declaration has no storage class or type specifier
WangLandau2d.h(92): error: expected a ";"
Where am I going wrong ?
icc depends on GCC headers and libraries. What version of GCC is installed on your machine? Your example runs correctly with g++-4.8.1. It also runs correctly with icc-14.0.1.106 if you have that version of GCC (or later) installed.
$ g++ --version
g++ (GCC) 4.8.1
Copyright (C) 2013 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
$ icc -V
Intel(R) C Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 14.0.1.106 Build 20131008
Copyright (C) 1985-2013 Intel Corporation. All rights reserved.
$ icc -std=c++11 U506774.cpp && ./a.out
1.12105 1.24086 1.94634 1.30563 1.01601 1.07346 1.17482 1.4248 1.39896 1.72678
patrick
what is the icc version? can you post the code snippet? the gcc version?
Jennifer
Version of icc is 13.1.0 20130121 , It is a random number generator
// Random number generator and distribution:
RNG rng; std::uniform_real_distribution<double> rnd;
do {
x = rnd(rng); y = rnd(rng);
} while(x*x+y*y>1);
I thought icpc 13.1 supported -std=c++11 (but not the temporary g++ option c++0x) when used with g++ 4.7 or newer, otherwise neither of those options would be supported. I'd be reluctant to try 13.1.0; the last 13.1 or most recent 14.0 seem better bets.
Same problem persists even with the icpc (ICC) 14.0.1 20131008 version.
Say for example, I want to compile this code,
#include <random> #include <iostream> int main() { std::random_device rd; std::mt19937 gen(rd()); std::uniform_real_distribution<> dis(1, 2); for (int n = 0; n < 10; ++n) { std::cout << dis(gen) << ' '; } std::cout << '\n'; }
I am getting errors like
rand.cpp(8): error: namespace "std" has no member "uniform_real_distribution"
rand.cpp(8): error: expected an expression
rand.cpp(10): error: identifier "dis" is undefined
$ g++ --version
g++ (GCC) 4.8.1
$ icc -V
patrick
I get it thanks :) !
