Intel® C++ Compiler
-std=c++17 fails with std::random on 19.0.4.243 20190416
sunwoo
*** test.cpp ***
#include <random>
int main(int argc, char** argv) {
   std::random_device r;
   return 0;
The above code fail with --std=c++17 on 19.0.4.243 20190416.
shell> icpc -std=c++17 test.cpp -o test
/tmp/icpcnzeTcw.o: In function `main':
test.cpp:(.text+0x39): undefined reference to `__builtin_is_constant_evaluated'
However, it is okay with both c++11 and c++14
shell> icpc -std=c++14 test.cpp -o test
shell> icpc -std=c++11 test.cpp -o test
shell>
I am using RHEL 7.6.
Sunwoo
Viet_H_Intel
spdlvme080 tmp]$ cat /etc/redhat-release
Red Hat Enterprise Linux Server release 7.4 (Maipo)
spdlvme080 tmp]$ cat t.cpp
#include <random>
   return 0;
spdlvme080 tmp]$ icpc t.cpp  -std=c++17
spdlvme080 tmp]$
Let me see if I can find RHEL7.6 to try.
sunwoo
This problem happened whent g++ 9.1 is used as a back-end.
Sunwoo
Vishnu
Is this an issue with the Intel compiler, or will the `-std=c++11` always be required, when using gcc >= 9.x as the backend? I'm having the same problem with the LAMMPS software package: https://github.com/lammps/lammps/issues/1585 I'm using: icpc version 19.0.4.243 (gcc version 9.1.0 compatibility)
Viet_H_Intel
