I just installed the Intel C++ Composer XE 2011. I've replaced all TR1 usage in my code with the Boost versions. However, std::pair is causing me problems.
The line of code is:
myMap.insert( std::pair( boost::make_tuple(x, y, z), boost::make_tuple(A, B, C) ) );
Tuple is a typedef:
typedef boost::tuple Tuple;
myMap is a std:map:
std::map Map;
These all worked fine with gcc.
How can I resolve this?
The error I get is:
main.cpp(776): error: argument list for class template "std::pair" is missing
detected during instantiation of "void Foo::run() [with dim=3]" at line 1163
/usr/include/c++/4.4.3/bits/stl_function.h(230): error: no operator "<" matches these operands
operand types are: const Tuple < const Tuple
{ return __x < __y; }
detected during:
instantiation of "bool std::less<_Tp>::operator()(const _Tp &, const _Tp &) const [with _Tp=Tuple]" at line 1170 of "/usr/include/c++/4.4.3/bits/stl_tree.h"
instantiation of "std::pair<:_RB_TREE_ITERATOR><_Val>, bool> std::_Rb_tree<_Key, _Val, _KeyOfValue, _Compare, _Alloc>::_M_insert_unique(const _Val &) [with _Key=Tuple, _Val=std::pair, _KeyOfValue=std::_Select1st<:PAIR>>, _Compare=std::less, _Alloc=std::allocator<:PAIR>>]" at line 500 of "/usr/include/c++/4.4.3/bits/stl_map.h"
instantiation of "std::pair<:_RB_TREE><_Key, std::pair, std::_Select1st<:PAIR>>, _Compare, _Alloc::rebind<:PAIR>>::other>::iterator, bool> std::map<_Key, _Tp, _Compare, _Alloc>::insert(const std::pair &) [with _Key=Tuple, _Tp=Tuple, _Compare=std::less, _Alloc=std::allocator<:PAIR>>]" at line 776 of "main.cpp"
instantiation of "void Foo::setup_system() [with dim=3]" at line 1069 of "main.cpp"
instantiation of "void Foo::run() [with dim=3]" at line 1163 of "main.cpp"
compilation aborted for main.cpp (code 2)
Many thanks,
Gennadiy
Hi Rishkin,
If you want to use boost library with Intel C/C++, you have to build boost library using Intel C/C++ first. As you've known that boost will use the same library for project. For example, boost will call MS library if the project is built with MS VC etc.
Wise
Wise
You say this line of code is causing the error:
and yet the error messageshows that the actual line is different:
Notice in the error message there is no explicit template argument list for std::pair.
Anyway if you can create a preprocessed file that compiles withg++ but not with our compiler please attach it. Use the -E option to create the file.
thanks
Judy
thanks
Judy
Topic Options
