A simple example, which I've attached, causes the Intel compiler (11.1 059 Linux) to take a very long time to compile, use a lot of memory and in some cases crash. I've also observed the same problems in the Intel complier for windows.
[shell]$ time icpc -o string_in_array string_in_array.cppHowever, with gcc it's fine:
Fatal compilation error: Out of memory asking for 36872.
compilation aborted for string_in_array.cpp (code 1)
real 3m51.597s
user 3m46.946s[/shell]
[cpp]$ time g++ -o string_in_array string_in_array.cpp real 0m14.287s user 0m12.877s sys 0m0.800s [/cpp]If I compile with no optimization it's a little better:
[cpp]$ time icpc -o string_in_array string_in_array.cpp -O0 real 3m20.380s user 3m17.324s sys 0m1.276s [/cpp]However, it uses 350MB of RAM and 100% cpu for 3m 20s. That's 14x slower than gcc.
Thanks for your report and the testcase.
I can see the problem on Windows as well. the icl never finish the compilation and run out of memory at the end.
I'll file a bug report to the compiler team. and will let you know when there's a fix or work-around.
Jennifer
When I tested on Windows, I added /EHsc for handling exception. That caused the out of memory. Without /EHsc, icl can compile fine with "-O2" or "-O3".
This test is very extreme, I'm wondering if you have such code in your real application. Could you let me know? So we can treat it properly.
Jennifer
